Results 1 to 13 of 15
Thread: Ductless Split
    Oct 2008
    MA
    Ductless Split
    Do fujisu ductless split systems use a scroll compressor?
    Massachusetts
    In my small world, all the manufacturer's are using a scroll in the mini-splits. Some have moved to inverter/variable speed technology. Mr. Slim by Mitusbishi is the big kid on the block.
    Clearwater, Fl
    Yes they use scroll compressors and inverter technology on most of their units as well. A couple of the 9k - 12k BTU systems do not have the inverter technology.
    If the model # ends with RLQ or RLXQ it will use inverter technology.
    As skippedover said, Mitsubishi has the largest market share in the states followed by Fujitsu. Mitsubishi has been sold here for a longer period of time than the Fujitsu.
    If people only focused on the important things in life there would be a shortage of fishing poles.
    Oct 2008
    MA
    Fujitsu Ductless Split
    Thank you for the response. I looked on Fujistu.com, read the install manuals and submittals, and they did not say whether or not they had scroll compressors. I have to do a quote for a customer who only wants a scroll compressor (A little knowledge is a dangerous thing in the hands of a customer...), so I thought I would put it out there.
    Sep 2006
    Quote Originally Posted by Quadguy800 View Post
    All Daikin models use scroll inverter technology.
    Clearwater, Fl
    I have had to go through that before as well and couldn't find any info on their site either. I went to a Fujitsu class a couple of weeks ago and that is what the companies reps told us. Actually they said that some were scroll and others were rotary.
    You're not going to get a recip to work the way that these compressors do, although you will have to figure out how to get your customer to understand this.
    Oct 2008
    Arizona
    Hmm
    [QUOTE=forcryinoutloud;2014766]Yes they use scroll compressors and inverter technology on most of their units as well. A couple of the 9k - 12k BTU systems do not have the inverter technology.
    What is inverter technology?
    Oct 2008
    Bellevue, WA
    I resemble that remark
    When looking for a heat pump I had my heart set on a scroll. They just seem inherently more reliable and quiet. It's very irritating (as a consumer) when companies "hide" the specifics. Trane for example calls everything a Climatuff compressor irregardless of whether or not it's a scroll, a recip, made in cooperation with Copeland or made in Mexico. They build a good product so it's hard to understand why they hide the technical info behind a wall of marketing hooey.
    Quote Originally Posted by mchild View Post
    i rather get Daikin than Mitsubishi.
    because we don't get top Mitsubishi ductless split systems here. the top ductless split systems from Mitsubishi Heavy Industries
    http://www.mhi.co.jp/en/products/det...lti-split.html
    All of the smaller minis I've seen use rotaries not scrolls!
    Same here.
    Newbury Berkshire
    Talking
    Quote Originally Posted by vq40de View Post
    Can you explain what you mean by this as I can read it but can't understand it;-)
    Cheers
    Richard
    All the Fujitsu Mini-splits manufactured for North America today use ROTARY compressors 9k-36kbtu The exception is the 42Kbtu unit (inverter scroll). Most are Panasonic Inverter rotary's, but a couple are normal 115v rotary's.
    The older R-22 stuff was recip/rotary mix (model dependent)
    Be Careful, The Toes You Step On Today May Be Conected To The A$$ You Have To Kiss Tomorrow.
