Results 14 to 20 of 20
10-17-2008, 10:04 PM #14
Professional Member*
- Jan 2008
- Dallas ,Texas
- 3,510
UA 100
It takes three people to do anything around here. Two do the work, one explains to the crowd of people who showed up when they seen smoke and flames.
10-20-2008, 09:13 AM #15
- Mar 2008
- 86
Funny no one else had a problem knowing what I was talking about. If you would read the whole thread you would know what I was looking for. Guess I will go tell my customers they can not call their systems VVT because we took the Carrier controls out.
10-20-2008, 09:23 AM #16
We also call our retrofits of this type of system VVT - even though we are not using Carrier controls. Just because I say zoning I could be talking about adding a baseboard heater with a manual thermal valve to a particular area, or a simple on/off damper based on time schedule/other. I do agree terminology plays a big part on most things, but for us VVT is a generic term meaning the kind of system - Variable Volume and Temperature which I do believe Carrier/Parker coined, however, whomever started the first VAV systems we have all figured out by now doesn't mean it's a brand x system. I would like to say technically speaking it would be pressure dependent/pressure independent but I can think of examples where that wouldn't work either to explain a VVT system without further details, where as a VVT type system tells me plenty.
http://threedevilskennel.com/ - not my website.
Versatile Hunting Dog Federation - www.vhdf.org/
10-20-2008, 07:02 PM #17
- Jan 2008
- Dallas ,Texas
- 3,510
Funny alot of people responding have Carrier in mind (i.e. okemechtech). It does make a difference because sequence of operation changes with different types of controls. Tell your customers what you want.
UA 100
10-21-2008, 12:13 AM #18
- Jun 2001
- San Diego, CA
- 1,146
do make sure you proof airflow BEFORE you turn the electric strips on and kill the fan and the heat strips if the limit trips.
10-21-2008, 06:56 PM #19
10-21-2008, 09:03 PM #20
- Dec 2006
- Hartford, Connecticut
- 440
Lets drop the VVT. How about a zoning system using zone dampers with auto changeover-bypass control.
What control system do you represent? If you do not want Carrier 3V you should look at Trane VariTrac and Honeywell RapidZone. They both work very well and are easy to install and setup.
