+ Reply to Thread
Thread: Lennox Variable Speed Motors
    Jun 2007
    South of Ft Worth at Keene Tx
    Has anyone tried to control a variable speed motor on a Lennox (or any other) unit? I have downloaded all info I can get to on the Lennox websites but wonder if there is more info availabe to Lennox dealers. I have also downloaded info from the GE website. I would like to know what the signal looks like (mA, volts, pulse width, ??) that actually tells the motor what speed to run.
    Thanks.
    Arizona
    I don't know about that but, we can now program Trane module's at our office with a newly purchased programmer. This will reduce our inventory and length of time to get a customer up and running. I'm hoping Lennox and Carrier will make there programming info available also.
    Make your expertise uniquely valuable.
    Make your influence uniquely far-reaching.
    Quote Originally Posted by jchapline View Post
    Thanks.
    It is 85HZ 15 VDC PWM. This is for all ECM motor designed by GE
    Pin #3 is for common of 24VAC
    Pin #15 is to start the motor (24 VAC)
    Pin #10 is the PWM to control the speed of the motor
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
