Results 1 to 8 of 8
    Apr 2008
    Upstate New York
    Whats a normal cycle period in mild weather
    60k btu furnace 2 stage firing on low stage thruout cycle, outside temp 45 degs stat set at 68 with inside temp at 66 how long should it take to get the temp to 69 and shut off ?
    What would be considered too lon and too short ?
    Too short, less then 4 minutes.
    Too long, more then 18 minutes.
    Nov 2000
    Eastern PA
    You have two systems in your home. There are too many variables to suggest what would be "normal" for your one furnace.
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
    Quote Originally Posted by RoBoTeq View Post
    I could swear he has only one furnace.
    Nov 2000
    Eastern PA
    Maybe I'm getting HO's mixed up
    Massachusetts
    A furnace should be sized by doing a load calc/Manual 'J'. If the load calc was done properly, then your furnace is operating as it should, regardless of the time. The time of the on cycle versus the dwell cycle will vary with each new outdoor temperature but also with a delay between the outdoor temp and what the thermostat senses. Why are you worried? Did you take the low-ball price and now have second thoughts? If you used a high end company that knows it's stuff, they did the Manual 'J', installed the proper size unit and you're all set. If however you went price shopping, you get what you pay for, that's all. If it's the latter, you'll know when the OAT drops to a design temperature day and if the furnace is too small, you'll be cold. If it's too big, it's short cycling (should be on 24-hours @ 2nd stage without stopping at design temp) and you wasted money on the purchase of a larger machine and have the anxiety of not knowing if it's properly sized or not. z sure hope it was the former and in that case, rest easy, it's done right!
    Apr 2008
    Upstate New York
    Yup only one furnace, Robo you aren't taking those drugs you suggested that I take are you
    Skipped, I bought the furnace I thought best suited me a Rheem RGRL 2 satge and it was far from the cheapest. I had looked at Carrier, Trane, Bryantt, Ducane, ThermoPride.
    3 of the above suggested the 60k btu that I bought, another suggested an 80k but this guy didnt do the load the others did. That said I assume they knew what they were talking about but I was curious as to cycling with outdoor temps mild.
    My old oil furnace was 105k and it ran a cycle of about 15-20 mins but it retained alot of heat and the residual would seep up thru floors and ducts .
    Just curious, thanks, by the way I never use price as a deciding factor
    Nov 2000
    Eastern PA
    Quote Originally Posted by cvcman View Post
    Yep, got you mixed up with another HO; sorry. As for taking drugs, I can't remember. Could be why I'm such a pleasant, tolerant type of a guy.
    As mentioned though, your system sounds fine. As long as it does not cycle off or at least mostly operates during extreme cold days, it is not oversized.
