Results 1 to 11 of 11
10-10-2008, 10:48 AM #1
- Jun 2006
- 4
Not quoting a 90%+ Gas Furnace on new system
I'm getting quotes on replacement for my upstairs system (walk up attic)
Current is a 1996 - Trane XE100/XE78 2.5-Ton
I got the quote back on a Trane and Goodman systems. I was a little surprised when they were only 80% units. Here's what he said:
Hadn't heard that one? I understand the water vapor but I would think the water pan would catch any spill over. We normaly don't have many weeks of below 32 in central NC either.I did not quote any 90% efficient furnaces because they produce water when they heat, and there is a possibility the drain line could freeze and cause water damage to the ceiling below.
Units Quoted:
Goodman GME80704BX - 80% - 2 stage
CHPF2430B6 - GSC13
(will field install a TXV)
Trane TUD1B060A9361A (XT80)
2TTR3030A1000A (XR13)
I'm thinking of having him quote the 14 or 15 Seer units along with a 90% efficient units.
10-10-2008, 10:52 AM #2
Professional Member*
- Jul 2008
- Poestenkill, NY
- 764
There was just another thread in here on this very same subject.
I am of the opinion that if it is installed correctly, a condensing furncae will live very happily in an unconditioned attic. What I mean by installed correctly - measures must be taken to avoid freeze-up issues.
Push them on it, or shop around, IMO.
10-10-2008, 12:06 PM #3
- Jun 2007
- The Twilight Zone
- 2,964
The heat pump should provide the majority of the heating requirement for your winters. I would indeed look into a 14 or 15 SEER with 12 EER and 9 HSPF ratings. Maybe the 90+ efficient furnace is overkill for your climate if the heat pump is primary heat and the furnace is auxillary heat. Is there a big $$ difference in purchase price between the 80% and 90+%?
Good luck.
10-10-2008, 12:21 PM #4
- Jul 2008
- Poestenkill, NY
- 764
Good point. But that model number is not a heat pump. (In fact, it's an R-22 cooling only unit, bad idea.)
If a heat pump were used - the gas usage might be so little that the extra cost and effort for the condensing furnace might not be warrented. The HP would be doing the vast majority of the work.
Look at the XR15i - it has good performance in heating. Depending on your rates - it is likely that the heat pump will be cheaper to operate - but that is a leap of faith without knowing your gas and electric costs. Is this LP or Natural Gas?
NG is usually so cheap its hard to beat, but a high efficiency HP can come out ahead. Plus, then you can have the 80% backup furnace knowing you'll hardly ever use it. Heck, maybe electric resistance back-up makes sense here...
10-10-2008, 12:32 PM #5
- Jun 2007
- The Twilight Zone
- 2,964
10-10-2008, 12:38 PM #6
- Jul 2008
- Poestenkill, NY
- 764
10-10-2008, 02:58 PM #7
- Jun 2006
- 4
Thanks for the advice. I'll search for the other thread .... got it.
http://hvac-talk.com/vbb/showthread.php?t=183744
Gas has moved around but it's been cheaper as a rule in NC.
I'd have to run more power from the basement to the Attic to switch to a heat pump; not worth the cost.
I was under the impression you needed new copper lines for 401 so I'm staying with R22 (if the lines are good). The run from the outside unit to the evaporator is around 50 feet (basement, two floors, attic). I'd have to tear up drywall run new lines or go up the outside of the brick (ugly).
Not to mention the cost of that copper.
I'll thinking of going to at least the 14 seer unit; not sure how much benefit there is on the 15i over the 14i 16 is 401 only and the 19 is too much.
10-10-2008, 03:41 PM #8
dual fuel system would not need heavier wire to attic.......
10-10-2008, 03:58 PM #9
- Jul 2008
- Poestenkill, NY
- 764
The direct cost of gas is cheaper than RESISTANCE electric per btu. You need to check what it is per btu through the heat pump, which is 2.5 or 3 times cheaper than electric resistance heat. This is a whole other topic you should research.
The heat pump replaces the condensing unit, which is outside, no wire re-sizing to the attic. R22 is being phased out and I strongly recommend against putting in new equipment with it, but whatever. A new line set is a small part of the cost of this job, and there are nice products that will hide the line set on the exterior - you don't need to run it through the walls again.
If you do decide to go cooling only, to answer the original question - a condensing furnace can be put in the attic if installed by the right people.
Check out the Trane XV95, very nice unit, I have one myself.
10-10-2008, 05:37 PM #10
- May 2007
- DC Metro area
- 3,223
Linesets don't always require replacement. Talk to your contractor about the options with reusing if you want to go with an R-410A system rather than an R-22 system.
10-10-2008, 05:59 PM #11
For the trane dealer, I would ask him to quote this package.
furnace- Variable speed blower/2 stage gas 80%- TUD060R9V3K
Heat Pump- 4twx5030A (15i) 1 stage compressor
or 4twx6036A (16i) 2 step compressor (they don't come in 1/2 ton increments)
This all depends of course on whether the sizes you were quoted already had a load calculation to come up with those numbers.
I would not put a condensing furnace in an unconditioned space, no matter the "normal" ambient conditions. Yes it is possible to prevent freezing, but if indeed your in an area that rarely gets below freezing, then the gas backup will rarely run making the upgrade to a 90+ not worth it, better spending the difference on the variable speed blower on the XV80 you will end up with a much better system than a single stage 90+ with a 3 spd blower (which I feel should be obsolete IMO)You can't fix stupid
