    Oct 2008
    Problem with sv9502H?
    I have an air ease ultra V 80 heater with an ST9160B board, SV9520H 8034 smartvalve, and programmable tstat. Every morning when the tstat calls for heat, the furnace does not turn on. The smartvalve flashes 10 times then pauses and does it again. In order to start the furnace, we turn off the switch on the side of the furnace, turn off the switch on the smartvalve, wait a couple seconds then turn on the smartvalve and side switch. I guess it resets something because the furnace turns on and works fine. I've read posts about smart valves not being reliable. Is there a way to troubleshoot the system to narrow it down? Thanks.
    Dec 2006
    Middle Tennessee
    Quote Originally Posted by Rick_P View Post
    yes there is, hire a qualified technician
    it's not worth the possible property or bodily damage you can cause trying to repair it yourself!
    Illinois
    Quote Originally Posted by Airmechanical View Post
    I could not have said it better.
