Thread: matching units
    matching units
    I have a 1.5 ton system, outside is a goodman heatpump #cpke18-18 and the inside is a first co. furdown unit #18hx5-240 with a 51 orfice. I've been told that I could use a 24x6 inside coil with a 59 orfice also a first co. I'm a little concerned about Low head, high suction, and possible floodback. Also would the effeciency be as good. Thanks guys
    Tn.
    Aug 2008
    yes you can use the 24x6 coil if you had to but losing your seer rating
