Results 1 to 13 of 24
    Confused dx chiller unloading
    on a recip chiller ie trane e compressor,
    why can't you use mechanical or suction unloaders?
    i do not understand.
    st65
    true knowledge exists in knowing that you know nothing.
    East of big city prices.
    How many tons is it? Are you sure it doesn`t have any unloaders?Maybe internal of the compressor?
    windy city
    didn't know there were any left in the field. 'e' and 'f' had an adjustment screw on the left manhole. some of the 'f' line had 3 electric solenoids on the right side
    Confused
    Quote Originally Posted by heavymetaldad View Post
    that is my question???
    why can't you use mechanical unloaders?
    why must they be electric???????????
    windy city
    Quote Originally Posted by supertek65 View Post
    not quite sure how to answer - probably need to change compressor to the style you prefer. i would think the indv. solenoids, depending how you fire em, would give more flexibility. the 'screw' type locks you in to 9 - 10# range
    One option would be put use some pressure switches to unloaded at your predetermined pressure settings.
    Pittsburgh,PA
    Just changed a model "E" last monday, it came with a mechanical unloader even though we needed the electric ones so we just had to change the hand hole cover. Model "E" and "F" compressors are no longer made just remanufactured in Charlotte N.C.
    windy city
    i stand corrected. haven't done it (swap covers). have to do anything with the oil lines?
    Pittsburgh,PA
    No oil lines need changed, just the hand hole cover.
    May 2008
    Jax Fl.
    Chillers do not use suction pressure actuated unloaders, only electric or Pneumatic.
    The suction unloader sideplate can be used on a chiller with a pneumatic 0-20 signal piped into the atmospheric reference port beside the setpoint adjustment.
    DX uses Suction unloaders or Pneumatic.
    Quote Originally Posted by JRINJAX View Post
    if a recip chiller has txv's is it not dx?
    May 2008
    Jax Fl.
    Usually DX [direct expansion] refers to directly cooling the load [air] and chillers cool the intermediate or secondary refrigerant [brine] in most instances.
    Aug 2000
    Austell, Ga.
    Many times I have tried to keep the suction pressure loaders on the E-compressor, modifying the various springs on the CNT-4,and as JRINJAX stated, you would need a RA pneumatic signal to the Lil' 1/8" pipe thread
    beside the adjusting slot cover nut to maintain a decent controlled temperature of CHW. If memory serves a 3psi/deg sensitivity worked quite well in the past.
    Personally, anything you can do to get away from that Hi-dollar 4-stage electric thermostat furnished will be an improvement....
    Ain't "None" of us as smart as "All" of us..
