Results 1 to 8 of 8
    Westchester Co, NY
    bryant system proposal
    Hello again
    So i finally got a quote in a hybrid system. Price not posted, however I would love to hear your criteque and comments, along with any questions that I should ask. Its a proposal with super duct - so I must see what the variable will be if I go with sheetmetal
    here it is....
    2 Zone Evolution Hybrid Heating and Cooling System
    Zone 1 – Entire 1st Floor
    Zone 2 – Entire 2nd Floor
    1. Install Two (2) Bryant Evolution Ultra High Efficiency Two Speed Puron 410A Heat Pumps with Two (2) Bryant Evolution Deluxe Variable Speed Gas Furnaces, each equipped with a Air Conditioning Coil, sized to heat loss/gain calculations as follows:
    Zone 1 – 95% Efficiency Furnace with 3 Ton Coil and 3 Ton Heat Pump Achieving 15 SEER and 11.5 EER*
    Zone 2 – 80% Efficiency Furnace with 2 Ton Coil and 2 Ton Heat Pump Achieving 15 SEER and 11.7 EER**
    2. Install Nineteen (19) Outlets
    3. Install Two (2) Bryant Evolution Controls
    4. Install One (1) Condensate Pump with Safety Switch
    5. Install Two (2) Refrigerant Linesets and Charge As Per manufacturer Specifications
    6. Install Venting Only of One (1) Stove, One (1) Dryer and Three (3) Bathrooms
    7. Install All Ductwork. All ductwork to be Super Ductboard
    8. All Grills to be white and Registers to be brown, all from Hart & Cooley
    9. All Low Voltage Connections
    10. Obtain Necessary Permit
    11. Start and Test System
    So what sticks out here as not right ( If anything) what should i get clarification on?
    any comments appreciated.
    thanks again folks
    Ask that the load calculation be AACA ,Man J or equal,and that the ducts be be sized per ACCA's Man D.
    Jun 2007
    The Twilight Zone
    Need exact model numbers of heat pump condenser, matching indoor coil, and furnace.
    Why are there astericks next to the word EER? Are those the actual performance numbers or general numbers?
    Need thermostat to handle all those bells and whistles.
    10 year PARTS AND LABOR warranty included? I would get it for such a high-end system.
    2 stage heat pump condensers sound like overkill for Upstate NY.
    Good luck.
    DC Metro Area (MD)
    No mention of return air?
    Jul 2000
    Northern Wisconsin
    Can you clarify why they are proposing a 90+ for the first floor and an 80 for the second?
    I second the "where's the returns?"
    To gary_g.... the evolution controls are the "thermostat"
    I agree with getting a quote on 10 year parts and labor warranties to cover the entire system(s) and then very seriously think about purchasing them.
    DC Metro Area (MD)
    My guess for why the 80% is quoted for upstairs is because less heat would, in theory, be used upstairs since some heat from downstairs would rise to the upstairs.
    Massachusetts
    The 80% is used in the attic so they don't have any fear of condensate water freezing the dead of winter. Those are not fun service calls, especially on a brand new system.
    I would want ARI Certificates before the equipment is installed. Are you intending to seek any rebates or Bryant incentives? If so, be sure all the equipment meets the necessary specs. Rebate forms should be on-line. Bryant forms from your dealer.
    2-Stage HP's are a good product, even up north. These are Hybrid Heat sytems so there's no need to run the HP on 2nd stage when it's relatively mild. Mines on 1st stage running right now and it's very comfortable. Slower blower, higher efficiency. It also has superior moisture removal in the AC mode come summer. 2-stage is a comfort thing far more than a 'how soon do I break even on the investment' thing.
    I agree with others. Manual 'J' is a must, Manual 'D' also and for that matter, Manual 'S' for equipment selection. It should specify return air in each bedroom as well as adequate return air for both/each system zones.
    Westchester Co, NY
    Gary - I will post the model numbers when i get them once i meet to discuss with HVAC guy. The astericks just denote the rebate available from bryant. ( one unit give 1100 and the other 1000)
    The warranty quoted is as follows
    Bryant Evolution Heat Pumps Warranty: 10 Year Compressor Warranty and Five Years on Parts.
    Bryant Evolution Gas Furnaces Warranty: Zone 1 – Lifetime Heat Exchanger Warranty and Five Years on Parts. Zone 2 – 20 Year Heat Exchanger Warranty and Five Years on Parts.
    They do not mention a warrenty on labor - is this normal?
    Each HVAC guy i have spoken to whether forced air or Hydronic, all quote a central return on each floor. Reason is that my area is not terribly big? does this make sense. ?
    Skipdover - you are correct with the reasoning of the 80% upstairs - I guess my HVAC guy was right on that. One question - what ARI certification do i need to see ( what is that for - ?)
