Thread: getting rid of b chimney
10-05-2008, 05:11 PM #1
New Guest
- Oct 2008
- 1
finishing up a new install of sidewall direct vent condensing water tank and condensing furnace. no longer need b chimney, need views on how to best seal up.
10-05-2008, 05:49 PM #2
If it's just a B-vent going up through the house, tear out what you can and put a plug (you can buy them at the big-box) of the same diameter as the vent in the bottom of it. That'll stop the chimney effect heat from escaping from the house. When you can, remove the whole thing as you don't need it anymore. Of course, you'll need to plug the hole in the roof or nature will visit.
10-06-2008, 05:43 PM #3
- Dec 2003
- 709
you could disconnect it in the attic and tie all your bathroom fans into it if they just poke into the attic now.
