Results 1 to 13 of 201
10-04-2008, 11:46 AM #1
- Oct 2008
- Michigan
- 29
Question: Three Stage Vs Modulating
So with similar sized systems and pricing for a 2500 Sq Ft house in Michigan I have to which contractor to go with based upon my gut feeling aftger interviewing the salemen regarding their company and feedback from this forum.
1) Is there a significant comfort advantage between a 3 Stage Bryant/Carrier Infinity (355CAV... and a Modulating York furnace (PC9-UP...) Both 4 ton AH and 100K input.
2) Bryant offers a 20 Year parts and Labor warranty on the HX whereas York offers lifetime parts (no labor). Are either of these warranties significant (failure rates of current equipment) and would most contractors servicing a Bryant with a failed HX fix it or try selling a new unit with a 30% (or so) credit which is probably the actual York strategy...
3) By buddy's 10 year old Bryant recently had the secondary HX fall apart. Have the new units changed the secondary HX design or materials? Does York have any real HX issues in their 90%+ line (I don't see class actions on York, but I do for Bryant)?
4) Any feedback on the reputation of Andy's Statewide (Orion) Vs Top Notch Mechanical (Waterford) regarding solving post installation problems (if this is against the rules, then please disregard). The BBB only lists Andy's with 2 resoloved issues.
10-04-2008, 12:13 PM #2
If you are comfortable having cold air blowing out of your registers and the highest gas bill on the block either one will work.
captain CO
10-04-2008, 12:50 PM #3
- Oct 2008
- Michigan
- 29
So what you're saying is that both of these systems which claim to be high-comfort solutions are really mis-leading the consumer. Thus based upon the brevity of your statement I guess from a comfort viewpoint I'm better off keeping my 20 year old single stage single speed Goodman 70% and investing in T-notes to compensate for the difference in fuel costs...
10-04-2008, 01:25 PM #4
If you go the Carrier be sure to get the Infinity control for best operation of the 3 stages. York's furnace does it all off of a single stage stat, not my favorite idea but with logic and temp sensors it works. Personally either would do the job. The Infinity control can do more with airflow and dehumidifcation if that's of any interest.
The issues with the Bryant/Carrier heat exchangers have been minor and are under warranty. Those furnaces are ALL OVER the place around here. We sure go through a lot of control boards but very rare to have a secondary heat exchanger problem on the 40" models, the ones sold today. The first generation 90s did have some issues with their secondary plugging up with junk & caulk.
We never hear complaints of cold air from our 2 stage furnace sales and nobody has ever complained about gas bills going UP on multistage furnaces. Our former Rheem supplier said his gas bill went down going from a single stage 90 to Rheem's Modulator.
10-04-2008, 02:15 PM #5
Modulating vs three stage is getting pretty sensitive. In theory, the modulating furnaces are going to be more comfortable. I also have not heard of cold air from the registers being an issue unless there is a problem with the way the systems have been set up.
As far as the cost factor, staged furnaces can be more costly to operate if they are oversized. A properly sized staged furnace will provide both comfort and efficiency.Government is a disease......masquerading as its own cureEcclesiastes 10:2 NIV
10-04-2008, 02:43 PM #6
- Nov 2004
- 209
10-04-2008, 03:49 PM #7
10-04-2008, 08:50 PM #8
10-04-2008, 09:13 PM #9Government is a disease......masquerading as its own cureEcclesiastes 10:2 NIV
10-04-2008, 09:18 PM #10
i may be wrong but i believe they are both stageing furnaces. York just has more stages then the others.
I believe lennox is the only one that has a true modulating gas valve and the rest are staging.
like i said i could be wrong
10-04-2008, 09:32 PM #11
10-04-2008, 09:34 PM #12
10-04-2008, 09:52 PM #13
the G-71 has a valve that will modulate up and down by the presure differantial accross the heatexchanger cause by the drat induce ramping up
this is determined by the board
it is also set to give the btu you need to heat your house and not run all the time.
it ramps up and then off. And is controled by stat and time and the board determines what btu it starts at each time it starts and will modilate up from there at certain percentages
i i remember right the rheem stages up and down determined by the stat. I am not sure it works off time also but it doent modulate from my understanding only stages
