Results 1 to 13 of 13
Thread: 410a question!
    Question 410a question!
    Could someone please tell me if they ever ran into a 410a unit that was installed wrong? I would like to know what was some of the problems they saw when someone maybe did not use nitorgen or ect....
    Thanks.
    carthage ms
    we had one that we went behind another contractor on that installed 410 equipment and some how managed to charge it with 22 and then couldnt figure out why it woulnt cool and walked a way
    The 2008 NATE TOP TECH!!!!!
    Alabama
    wrong txv
    had one where a contractor put in the wrong a/h on a change out.
    had a r-22 txv in it. didn't work to good with 410a.
    Not using nitrogen on a R410A system will have no more effect then on an R22 system.
    Houston,Tx.
    We had a 410A Trane unit once that we put Puron in and it would not work, it keep flashing wrong MFG. code on the board.
    Tn.
    Well there you go you put Puron for Carrier in LOL
    I bet people that say freon bother you like it does me.
    I get a bunch that still say freon when dealing with 410A
    thats wrong on at least 2 levels
    Jan 2002
    Ft.Worth,Tx
    'Life begins with the journey each day'
    Jun 2007
    Round Rock
    What problem are you having that makes you think it wasn't installed correctly?
    I like going to Lennox and ordering a jug of Puron, it gets them everytime.
    Orange Park Florida
    Did you want the "pink" jug?.......Or the "Dusty Rose"one?
    Local 234
    Have Gauge$ Will Travel
    Morehead City, NC
    You know it's just wrong when....
    You walk up to a 410 unit for a call and it has "R-410A ONLY!!!!!" written on the access panel in fat black marker... and they wondered why it did not work right since the day it was installed - 4 of the same unit at the place, must have been the one they put in first...
    "The truth only hurts when it should"
    As well it should!!! lol!
    Oct 2008
    410-a
    R410-A is a chemical make up. Puron, Environ, and the pink jug all have the same chemical #. Try to put the pink jug in trane, carrier, or lennox units and set up by sub cooling and all will operate normaly. My company is adealer of all three manufactures. I have charged all three with the PINK jug andall have given me 16 to18 degree temp drop. Our installers have also screwed up and mis matched 410-A with 22 it is a royal pain to try and clean up due to the fact oil stays in evap coil. Recomend seriuos nitro purge along with dryers and multiple changing of them. I'm still waiting for a comp failure. It's going to be a long learning process for all field techs when this happens to any one.
    South Carolina
    Quote Originally Posted by hvacman14 View Post
    sounds like alot of fun
