Results 1 to 2 of 2
10-02-2008, 02:16 PM #1
New Guest
- Oct 2008
- 3
Bryant Evolution 288ANA Fault Code 56
I recently had a Bryant Evolution System installed in my home last July:
355CAV060
288ANA060
System worked great all summer in A/C mode and now that temps are cooling down and HP is working, I have been getting a Fault Code 56 on the Heat Pump:
56 - Temp Sensor Out of Range
The counter is up to 6 events as of today.
The HP is operating just fine and indoor temps are right on. I only discovered the Fault 56 because I monitor the advanced settings once a week or so.
Before I contact my installer, I am looking for some thoughts/advice about this problem so I can brief them accordingly and let them know what I want done about it.
Thanks so much!!
10-02-2008, 02:26 PM #2
- Jun 2007
- The Twilight Zone
- 2,964
Please don't take this reply as a smart a$$ answer.
I would simply call them and tell them that you have 6 events showing Fault 56 - Temperature Sensor Out of Range. Let them figure out what needs to be done. Parts and labor warranty is still in effect so there should be no charge for a house call if needed.
Good luck.
