    kelvinator heat pump Model# GB5BM
    I had my heat pump installed in a new build. I had ran it in cool mode for 3 months and the system still comes on but I get no air movement out of the vents. The cooling fan on the outside unit comes on but there isn't any air coming out of the interior floor vents. Any help?
    If its a new build, its still under warranty.
    Call your builder, or HVAC contractor.
    Could be several things. A service tech can find out what in a few minutes.
    call a contractor, could be blower capacitor but i'd bet with that equipment it's the blower motor that needs to be replaced. have seen it a lot in this brand. unless you have a leak and the coil is frozen and not letting air pass. could be a few things, would call a trusted contractor and let them diagnose it. check your filters also make sure they are not plugged causing the coil to freeze
    Thank you for the advice, I will call someone in the morning. Was just hoping there was a switch to flip on it somewhere. Thanks again.
    we can't put those switches on there vicki we'd be out of business
