Page 1 of 6 123456 LastLast
Results 1 to 13 of 66
    Apr 2008
    Upstate New York
    What holds the A coil in place ??
    I bought a roll of metal duct tape and started taping all the duct joints. I taped around the area where the a-coil is too.
    What holds that A-Coil in there??
    Also how would you ever know IF the drain got plugged and does it happen often ???
    Thx
    Western NC
    ummmm magic
    yup thats it. magic screws.
    and if the drain backs up, you'll know once its too late.
    and it happens quite frequently if your not on a service contract. If you are on a contract, your chances are slimmer but still likely.
    Jun 2008
    west point, ga.
    Quote Originally Posted by iraqveteran View Post
    ummmm magic
    Damn, now the cats out of the bag.
    Western NC
    Quote Originally Posted by RDP View Post
    well you shoulda never put the cat in the bag....
    you know how pissy cats can be!!!
    Jun 2008
    west point, ga.
    Well I was going to drop the dog in there to but it got out to quick.
    Western NC
    so what your sayin is...
    you gotta pissy pussy and your stuck holdin a bone in your hand???
    Jun 2008
    west point, ga.
    I always end up screwed at the end of the day.
    Unhappy
    Quote Originally Posted by cvcman View Post
    Thx
    What holds it in there??? Gravity
    IF the drain got plugged, you'll have a wet floor. Yes, it happens often if you don't get it checked/cleaned each spring.
    Duct tape is good. Fix's most anything. Noisy wife... tape mouth. Leaky kids,, tape butt. Leaky duct work... tape leaks..... so on and so forth.
    Lets not forget the majic smoke in the control board... if you let that out, it will never work again
    Shelby Twp MI
    Thumbs up
    Aaaaahahaha
    Jim
    Western NC
    Quote Originally Posted by tinmarine View Post
    Aaaaahahaha
    well at least someone enjoyed my hard sense of humor
    Apr 2008
    Upstate New York
    So..... does the acoil just slide in there on a sheetmetal flange and the metal tape holds it in there ??
    How would they check the drain without removing the acoil ?? I see water running from mine when its going so it must not be plugged >>>
    It seems IF it plugged up it would run into the heat exchanger area ???
    Where would you chesk it from time to time to see if its plugged ??
    Jun 2008
    west point, ga.
    Most of us do.Some are a little to serious.
    Western NC
    agreed....
