    Somewhere, WI
    Adding an Ethernet card to a Soft Jace
    Has anyone done this to have bacnet/ip on a separate network just like a 201 or 600 can? Does it work?
    San Diego, CA
    Quote Originally Posted by ddcfreek View Post
    Yes this can be done. The technical term for this is usually referred to as a multi-homed setup. You specify which network card to bind to when setting up bacnet/ip network. Remember to check your firewall exception list (UDP port 47808)
    http://www.topwebhosts.org/articles/...homed-host.php
    Oct 2005
    Easy upgrade. As digo states, just make sure you have BAC0 open on your firewall and all should be good.
