Results 14 to 18 of 18
    Jun 2001
    Michigan
    lets all slow down.
    I think were all talking different things here. And I mucked it up even more.
    If it is a service meat case, or a multideck meat merchandiser, then a 28 degree discharge air temp is the acceptable means to acheive meat optimum temp. Actualy, anything above 30 degrees and your shelf life will go to $hit.
    If it is service deli, and I don't think it is, after rereading the first post and after I assumed it was and went way long in the wrong direction on my first post, then we got different things to look at. As a matter of fact, if it's service deli, alot of what I said in my first post I will keep.
    The poster said MEAT. Meat has to be kept at 28 to 30. Above that and your customer will be very upset with you.
    Nov 2005
    Haymarket VA
    Quote Originally Posted by Dchappa21 View Post
    Never seen a meat case that runs 38-40'f
    If you can't tell the difference between a bad defrost clock and low on charge, I would tell him to call a pro.
    you are not tech . i can tell .i think this is enough info for end user
    Oct 2006
    Boston
    Quote Originally Posted by sarpanch2001 View Post
    Yah, it's all the same in theory. Should have noticed that earlier.
    Nov 2005
    Haymarket VA
    Quote Originally Posted by 537refergirl View Post
    first time when i touch gauges that time i learned from my S tech how use pt chart
    we do this work for living . hvac guys know how to use PT chart
    thanks for all the help and BS.. sorry i dont have a pt chart for 12 i my gauges have 134a instead... but anyways it was the timer for those who were actually trying to help
