Results 1 to 4 of 4
    passive fresh air vent with damper
    Is anyone aware of a passive fresh air vent unit that has a damper inside which will allow outside make-up in but keep conditioned air from escaping? In other words, one that will only open when there is negative indoor air pressure?
    Sterling Heights, MI
    Combustion Air
    Field Controls (fieldcontrols.com) makes several products to make up air. Look under Contractor Products, Combustion Air and scroll down to Makeup Air System. The style you refer to is a MAS 4 or 6, meaning 4inch or 6inch., which will open under negative conditions. Look at their great information and new training area too!
    NW burbs of Detroit
    These are easy as pie
    http://www.skuttle.com/
    Post thanks
    thanks for the tip
Comfortech365 Virtual Event
