Results 1 to 11 of 11
Thread: threads on oil drain
09-23-2008, 08:05 PM #1
- Sep 2006
- 19
What is the best thing to put on the threads for the oil drain plug and fill plug on a compressor?
09-23-2008, 08:25 PM #2
- Aug 2000
- USA
- 4,934
567 Loctite.
Your poor planning does not constitute an emergency on my part!!!!
09-23-2008, 08:39 PM #3
Professional Member*
- Jun 2004
- St Paul, minnesota
- 766
oil
09-23-2008, 08:50 PM #4
- Sep 2006
- 19
they won't leak with just oil?
09-23-2008, 11:52 PM #5
I'll go for the 567, that stuff is magic in a tube.
I would think just oil should work too though, 99% of the job of a pipe dope, pipe tape or anything else is just to lube the threads..."If you call that hard work, a koalas life would look heroic."
VETO PRO PAC, The Official Tool Bag of HVAC-Talk.com
Testo... you guys rule!
09-24-2008, 06:00 PM #6
- Sep 2008
- Cedar Rapids, IA
- 473
A service valve with teflon tape works for me.
AB and POE oil seems to have an easier time making a leak thru thread sealant goop then mineral oil did.
09-24-2008, 08:42 PM #7
- Aug 2000
- USA
- 4,934
09-26-2008, 09:08 AM #8
- Oct 2007
- Maine
- 11
Locktit or Oil both are acceptable an work on the compressors we service.
09-26-2008, 10:21 AM #9
- Jun 2008
- Apopka, Florida
- 110
drain plug
You should only have to use oil, plugs should have an gasket or rubber rings to seal, or at least all the ones I have seen. Oh by the way torque it to the manufacture torque specs, if your gasket or ruber rings is damaged get a new plug.
help the next guy ou unless your married to the unit.
09-26-2008, 05:56 PM #10
Teflon tape has always worked for me.
"My hands are for sale"
09-26-2008, 07:57 PM #11
