    Aug 2008
    Bethel,New York
    No station copier function visible
    Workbench, when I open a platform connection to a Johnson Controls Niagara host (model #FX-40),
    that host’s available platform functions are listed in the platform’s Nav Container View on the left hand side of the screen.
    I am connected to the platform and have opened the station.
    The point extension manager is functioning,
    I do not see the station copier function in the Nav view.
    I need to copy modules from my loacal host to the remote station
    San Diego, CA
    Quote Originally Posted by stuckagain View Post
    The Station Copier view should be available under the platform view of the remote host (it does not appear under the local host's platform view in workbench, only when you are connecting to a remote station).
    If you are in need of copying modules to your remote host, I suggest you do so via the commissioning wizard (right-click on the host's platform).
    The other option is via the software manager view of the remote host, also under the platform.
    Aug 2008
    Station Copy Function
    Station Copy Function is not normally used for coping individual modules. It is for Uploading or Downloading an entire station.
    As mentioned the commissioning wizard or software manger would do this for you. You can also copy individual files using the windows like
    drag and drop from your Host My Filesystem to the FX-40 Files system. (Px Files, Background Bit Maps, Text Files, Pdf's ect).
    Mount Airy, MD
    This is the Mo Better way
