    Southeastern Pa
    Honeywell Vision Pro
    Maybe one of you knows the specific reason for this.
    When you install a Vision Pro programmable thermostat, there is a small plastic tag that you are supposed to pull out after installing the thermostat. I can surmise that the tag us used to separate some electrical contacts that either connect a memory battery on the board or initiate some sort of counter.
    The ones I take out of service are usually toast, so there is little to investigate. Anyone know the specific reason Honeywell uses this tag? I don't see it used on other brands.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Jun 2001
    San Diego, CA
    yep, its for the battery
    Alabama
    If I remember correctly, It has an internal battery for EEPROM memory. That tab insulates it.
