    Oct 2007
    Huntsville, AL
    Echelon Ilon 100
    I am new to the Echelon ilon 100 and I am wanting to view a LNS database with it I have Circon NI on my computer and I have the ilon 100 discovered into that database but I still cannot see any devices that are on my database with the ilon 100 I was wondering if anyone could help?
    New England
    Is it a SmartServer or an e3? If it's an e3, you should see your network on the external points page of the plugin where you can add points (NVEs). If it's a Smart Server, you need to install and run SmartServer Enterprise Services and set up your browser to allow the connection.
    Oct 2007
    Huntsville, AL
    It is an e3 when I try to open my plugin it shuts down and says it has caused an error and needs to shut down. But I know when I am building the site in vision when I try to find my NVE it says there are none...
    New England
    Until you run the plugin and add points, you'll see no points in Vision. I suggest you reinstall the plugin, re-register and try again.
    Oct 2007
    Huntsville, AL
    Thanks alot! Now I know where my problem is! I will try to de-register it and re-register it.. if that dont work guess I will call them! Thanks alot
    Oct 2007
    Huntsville, AL
    Thanks I got it working! For some reason the plugin would only work in LonMaker and not in Circon Network Integrator....
