Results 1 to 7 of 7
    Feb 2005
    Need help in adding a second thermostat
    I built our 3 level home about 4 years ago. It has 3 zone manual dampers (one zone for each level) on an American Standard 2 stage furnace. I have a Honeywell 7 day programmable 5 wire thermostat on the middle level of the house.
    The only problem with this setup is in the summer we need to set the thermostat very low to allow the AC to kick on and cool the 3rd floor enough to keep us comfortable (all the bedromms are on the 3rd floor). I have the dampers adjusted to have most of the flow run to the 3rd level during the summer, but at night the middle level cools off faster than the 3rd level so the thermostat doesn't kick on unless I have it set really low.
    I have a thermostat wire run from the furnace to the 3rd floor and I was thinking it would be more efficient to install another thermostat on the 3rd floor to solve my summer cooling problem. I probably would only need to use this second thermostat during the summer.
    Can I hook this second thermostat up in parallel with the other thermostat at the furnace or will I need some kind of zone controller?
    Thank you for the help!!
    Tn.
    Need help adding a thermostat. WTH call a hvac contractor holmes.
    Feb 2005
    I did all the wiring for all the HVAC in my house so I am just looking for a little guidance with installing another thermostat. I'm pretty confident I can handle this task myself with the assistance of a very helpful online community
    Jun 2008
    Kansas
    First read this thread
    http://www.hvac-talk.com/vbb/showthread.php?t=1241
    Pay attention to #2
    If it were me, I would look at installing a honeywell touchscreen stat, and a remote indoor sensor upstairs. This would allow you to use the same stat, but switch the sensor on and off seasonally. It would be MUCH EASIER than trying to configure two thermostats correctly to one unit.
    Feb 2005
    Quote Originally Posted by jdkasper View Post
    Pay attention to #2
    Sorry, my bad...
    Tn.
    I just paid a car mechanic $175 to fix my truck. Could I have fixed it...possibly.
    But thats what they do so I took it to them.
    Much easier to pay the mechanic than get into something I don't understand and screw something up. End up costing me more.
