Results 1 to 7 of 7
    Oklahoma City
    Help to Determine SEER Rating
    I have been quoted two BRYANT systems and not sure how to determine the SEER rating for a system. The two systems are:
    SG91BM14/48/100MBTU
    Furnace: 350MAV048100
    Condensing Unit: 114ANA048
    Evaporator Coil: CNPHP4821ATA
    SG81MB14/48A/90MBTU
    Furnace: 310AAV048090
    If this changes by 1/2 ton after they do a load calculation will that change the SEER rating by a significant difference??? Any others comments about this system???
    Thanks!!!
    Rick
    bowie md
    both are 14 seer only furnace differance
    Atlanta area
    Quote Originally Posted by Indycar29 View Post
    ... If this changes by 1/2 ton after they do a load calculation ...
    Seems like the load calc could/should also better determine which furnace is needed. SEER doesn't apply to furnaces, in case you're wondering, but the furnace could influence the AC's SEER rating if the furnace is a variable-speed model.
    Hopefully I remembered that right and didn't gloss over anything. I think it's why you see condensers often rated for "up to" a certain SEER. In other words, 13 SEER or 14 SEER when paired with a VS furnace.
    Jun 2007
    The Twilight Zone
    www.AHRIDirectory.org
    Air Conditioning, Heating and Refrigeration Institute Directory.
    You can look up your model numbers on this site.
    Good luck.
    Oklahoma City
    deckeda
    Thanks for the input! I think its oversize abit, that's why I confirmed that they would do a load calc if they got the job. The price will come down a few hundred per 1/2 ton, so that will help with the price.
    Rick
    Oklahoma City
    That form is confusing for those not in the industry. I get from 10-100 hits, when I do a search.
    Thanks!
    Rick
    Feb 2007
    I don't find any ratings with that N coil. I know that is not right. I am sure a Bryant guy will be able to answer this soon. good luck
