Results 1 to 13 of 37
Thread: Heatpump comfort
09-16-2008, 11:05 PM #1
- Jan 2007
- Westchester Co, NY
- 104
Heatpump comfort
I have always understood that heat from a hydro air system is the most comfortable out there outside of Radiant. How does heat from a heat pump match. Is it dry, uncomfortable, drafty etc?
Is there any consideration to running the ducts -again I am reading that the ducts play an important role in making sure a heat pump distributes heat correctly - However i cannot find anything specific on this
Thanks again everyone
09-16-2008, 11:36 PM #2
Like any duct system, it has to be sized to the CFM the rooms requires.
09-17-2008, 08:00 AM #3
- Jan 2007
- 104
Are there some considerations to duct placment (maybe all installers do this correctly) but i I thought i read somewhere that they need to be in the floors vs ceilings. I know any of the guys I have spoken to indicated that the flow ducts would be in the ceilings. Assuming the correct sizing - is this correct - or should the ducts be in lower to the floor, with returns in the ceilings
Also - if anyone can comment on heatpump feel and comfort from your experiance - I would appreciate it.
thanks
09-17-2008, 08:31 AM #4
Banned
- Dec 2006
- Middle Tennessee
- 11,347
both ceiling and floor installations of ductwork have their advantages and disadvantages!
the "feel" of a heatpump while in heating mode can "feel" cold and drafty if the supply grills are blowing directly on you!
if the supply grills are not blowing directly on you then you have no problems and everything feels comfortable!
09-17-2008, 08:47 AM #5
- Dec 2007
- East central Indiana
- 477
Customers ask me this question all the time. I have no idea what this means. My boss is more of a "people person", so whenever this question is asked, I just sort of fade away, and he takes over.
I mean, if you're in a house where the stat is holding a steady 72 degrees, then it's gonna feel like it's...well, 72 degrees. Right?
So. If you could do me a huge favor and explain in a bit of detail what you're asking, then I would be greatly indebted to you.
09-17-2008, 09:25 AM #6
- Jun 2007
- The Twilight Zone
- 2,964
Furnaces put out 120F air temps, or so. If you feel the air coming out of the registers with your hand, it feels hot because your hand is around 91F or so.
Heat pumps put out air temps in the mid 90's. Their output temps drop as ambient temps drops. An output temp in the low/mid 90's may feel "cool" to the hand which is similar in temperature.
Take care.
09-17-2008, 09:32 AM #7
- Dec 2007
- 477
09-17-2008, 09:42 AM #8
People switching from gas to a heat pump. Take a while to get use to the cooler temps of the heat pump.
So at first, it may not seam as comfortable.
In a heating climate. Supplies in the floor, do a little better then supplies in the ceiling.
If the supplies are in teh ceiling, you have to be a bit more selective about what register you use for heating.
09-17-2008, 09:49 AM #9
- Jun 2007
- The Twilight Zone
- 2,964
09-17-2008, 09:52 AM #10
- Dec 2007
- 477
09-17-2008, 09:56 AM #11
- Jun 2007
- The Twilight Zone
- 2,964
09-17-2008, 09:58 AM #12
- Dec 2007
- 477
09-17-2008, 10:02 AM #13
- Jun 2007
- The Twilight Zone
- 2,964
