Page 5 of 7 FirstFirst 1234567 LastLast
Results 53 to 65 of 79
  1. #53
    Rochester, MN
    Quote Originally Posted by MikeC78 View Post
    HA! Too funny... I only had ONE Carrier quote, another was a Bryant. To be totally honest, I had one quote for a 115,000btu furnace and all the rest were 100,000.
    Have they shown you a print out of the Manual-J (Load calc)? They measure each room, walls, windows, and attic? If your old one was 100k, sounds like they just matched what was already in the home itself.
  2. #54
    I figured out how to check the static pressure on the controller. I don't know if this means much right now, but with the heat pump cooling on high the static pressure is .31
    Airflow CFM's are reading 1030.
    Your running in comfort mode.
    At 1730 CFM in third stage heat you'll be at roughly .87".
    Allowable, but at the high end.
  3. #55
    Apr 2008
    Princeton, NJ
    Repost of Pics
    I don't know why people can't see pics? Email me and I'll send them to you.
    cvetanma at yahoo dot com
    I could not see your pics at home but I can see them at work so I am doing a test and reposting them to see if I (and others) can see them.
    Let me know if you could not see them in post 1 but you can see them here.
    Key1
    In the land of the blind.....the man with one eye is king....
  4. #56
    Can't see them in either.
  5. #57
    Rochester, MN
    Quote Originally Posted by key1cc View Post
    Key1
    I saw them yesterday, today I don't... This is not the only post.. I think there is something wrong with HVAC's host site for the photo?
    I can see the photo when people post it the other way (full view in post)
  6. #58
    I tried both Firefox, and IE. Can't see them using either browser.
  7. #59
    Let me know your email and I'll send them to you. My email addy is posted in this thread.
  8. #60
    Pittsburgh PA
    Hotwater tank
    I believe you said you had an 80% furnace. Was the flue tied in with the hot water tank? Does the tank flie have a 3" liner in the chimney?
    What was I thinking??? I never do that again!!!
  9. #61
    Quote Originally Posted by TEK723 View Post
    Yes, it was. My new one is vented with a coencentric PVC pipe.
  10. #62
    Apr 2008
    Princeton, NJ
    Quote Originally Posted by mayguy View Post
    I agree, I saw them an hour ago in both posts from my home computer....now I can't see them in either.
    Did someone notify the moderator?
    Key1
  11. #63
    Hopefully they used vanes in the return drop where it connects to the air filter.
    Power humidifiers, don't work real well installed on the return.
    In order to add moisture to the air, they need heat. And there isn't a lot of heat in the return air.
    As others have said, pump up under the outdoor unit would be nice to protect it against snow accumilation.
    Canvas would be nice, and is actually a code. But may not be enforced in your area.
    Other then the humidifier on the return drop, and no pump ups under the outdoor unit, I didn't see anything terible.
  12. #64
    Apr 2008
    Alberta Canada
    How you getting this number?
    Why do you say 1730 beenthere. The cfm at .5 is 1510 and just wondering where you are getting1730
    Do it right the first time.
  13. #65
    93,000 BTU output, at 50° temp rise requires roughly 1730 CFM.
    At 1510 CFM, it would give a temp rise of 57°.
