Page 3 of 7 FirstFirst 1234567 LastLast
Results 27 to 39 of 79
  1. #27
    I'm not versed on it well enough to tellyou how.
    And I don't have the manuals in front of me.
  2. #28
    Well, I remember when they initially set-up the unit that the controller went through a static check and everything came out to normal. They ran the furnace on high, and the 3rd stage did kick in. I'm assuming the brain box would be giving me an error or static error if the pressure wasn't normal?
    The manual only states a pressure check upon set-up, doesn't give you an explanation on how to go into that mode.
  3. #29
    BTW, the OUTPUT BTU's as labeled on the furance are as follows:
    LOW - 38,000
    MED - 61,000
    HIGH - 93,000
    INPUT:
    40, 65, 100,000
  4. #30
    It does in the installtion manual.
    You could be running at 1.1" when in third stage, and not get an error. But thats still to high.
    Since you only need to move roughly 1200 CFM for the A/C, your static won't be as high, as it will be if it ever goes to 3 stage heat(roughly 1730 CFM).
  5. #31
    I can tell you that it's under 1", if it was over a warning or error would appear. The guy is on his way now, I'll have a better answer for you.
  6. #32
    Lincoln, Nebraska
    Don't forget to ask them about the pump ups for under the outdoor unit. As stated when you have a foot of snow you will still want that unit to drain. We always use them here in Nebraska.
    Its a good Life!
  7. #33
    Apr 2008
    Princeton, NJ
    Quote Originally Posted by MikeC78 View Post
    I can email them to you, I don't know how to host them on here? PM me your email addy if you'd like...
    Nevermind, I just viewed your profile and emailed them to that account. I hope you don't mind...
    I can see the pics from my work computer.....don't know why I could not see them at home yesterday.....sound like some other folks had the same issue. (No I don't mine being emailed, thanks). I agree with what was said already about static pressure and it will be real interesting to see what numbers they/you get in 3 stage. I reccomend that you have them show you how to check for yourself so you can evaluate the impact of different scenarios.
    Key1
    In the land of the blind.....the man with one eye is king....
  8. #34
    bowie md
    THE GAS COCK IS NOT UP TO CODE AND SHOULD HAVE BEEN REPLACED
  9. #35
    bowie md
    CANVIS ALSO NEEDED ON SUPPLY PLENUM FOR NOISE
  10. #36
    Quote Originally Posted by grumpy20716 View Post
    What's wrong with it?
  11. #37
    I asked him about that, he says he doesn't recommend them. He said there isn't really any noise issue without, and that they don't last forever and can rot? I can tell you right now that I can't even hear it running, even on high.
  12. #38
    bowie md
    no noise yet ! vinyl canvis will not rot .just a cheap investment . over time there will be some vibration transmited thru ducts
  13. #39
    You are not the first person to tell me this, sometimes I wish I did that. However, I didn't have noise before with the old unit. Would that be different for a newer one?
