Results 1 to 12 of 12
    Nov 2005
    Shreveport, Louisiana
    Trane VAV UCM 4.2
    I have a problem on this box and there is no front end to look at the system. What trane software can I use to access this controller. I want to look at the setpoints/parameters etc and not sure if I have to do any program editing.
    UA Local 141
    Sep 2006
    Alaska
    Rover
    You need Rover Service tools and a connector kit
    Nov 2005
    Thank you
    UA Local 141
    Pacific Northwest
    Quote Originally Posted by berg2666 View Post
    To be a little more specific, you need Rover with COMM-4 hardware kit. Rover has two hardware options, COMM-4 and Comm-5(LON).
    The other option is to use an older DOS software & hardware package called 'Everywhere' (it's been discontinued). To use Everywhere on a UCM 4.2 you will need version 1.35
    Hope this helps.
    Knobber
    Nov 2005
    Comm 5 is LON and comm4 is (trane proprietary)?
    UA Local 141
    Yes comm4 is trane proprietary
    Jun 2001
    San Diego, CA
    Choose your computer wisely. Once your copy of Rover is installed it phones home and locks it to that computer.
    Apr 2008
    Louisiana
    If you are having problems with the box its not likely to be a programming issue. If it is an older box (Varitrac) it is more than likely a drive problem. There are three wires that hook up to the controller. Common, open, close. You can take the open /close drive wires off the board and touch the open wire to the common. Vice versa for closed. Make sure the end switches are making and that they kill the motor. Most of the time I am asked to work on a TRANE box this is usually the issue. Or those POS Erie actuators they use for reheat control.
    Tennessee
    Quote Originally Posted by gbfromsd View Post
    You can transfer rover to any computer but you can't have it on more than one without buying more than one copy its that whole copyright thing you know god forbid the manufacturer charge money for things they make we shouldn't be allowed to make money only contractors and service company's huh
    Dell works best with Trane Software. Without all the extra junk on it.
    Apr 2008
    Quote Originally Posted by GONFISHN View Post
    Yup. And the little motors burn out regularly, and can be a pain to replace!
    Just guessing, but if I were a betting man, I would say that this isn't a cone damper with the motor that has the end switches. The reason that I say that is the thread title says "UCM 4.2". All of the older cone dampers that I have seen are UCM 3 or 4.0. But I said betting, not saying that this is the case.
    And you can move rover to another computer, maybe they give some people some grief, but I've never had a problem with it.
