Results 14 to 23 of 23
Thread: transformer issues
09-16-2008, 05:23 PM #14
- Apr 2008
- il
- 19
not a diyer
im no diyer, just ran that call today and the problem was in the contactor. 1 year old unit. now i will figure out how to apply for pro.
09-16-2008, 05:47 PM #15
- Feb 2006
- Tn.
- 1,331
What kind of problem in the contactor?
How'd u find it?Last edited by m-cooling; 09-16-2008 at 06:45 PM.
09-16-2008, 10:19 PM #16
Get your post count to 15, and apply.
Much better answers when you ask questions in the pro tech forum.
09-16-2008, 11:38 PM #17
No return.
- Jul 2006
- NW burbs of Detroit
- 6,058
Would have to say that would depend on how the loads are distributed on the board.
Consolidated furnaces had no fuse on control board. They would sacrifice the xfmr in case of a short. Makes sense since an xfmr is the least costly part on a furnace.
Had one go on me late last winter so i replaced it and added a mini breaker.
09-17-2008, 08:30 AM #18
- Dec 2007
- East central Indiana
- 477
BTW, you have mentioned Consolidated & Texas Furnace a few times. Do you use these furnaces?
If so, have you noticed that the Honeywell board on these things is prone to burn up at the blower relay? And have you found out what causes this, or how to prevent it? It seems like it's always the solder joint in one particular location. I've resoldered them before, and they work at the shop, but I'm kinda afraid to put them back on in residences.
The 80% furnaces have moved away from this board, but the 90%ers still use them.
09-17-2008, 09:31 AM #19
- Sep 2008
- Florida
- 34
Contactor sounds like likely suspect but I would still check the low voltage wiring. Could have a nick on the insulation.
09-17-2008, 11:36 AM #20
No return.
- Jul 2006
- 6,058
09-17-2008, 11:46 AM #21
- Dec 2007
- 477
09-17-2008, 11:56 AM #22
No return.
- Jul 2006
- 6,058
09-17-2008, 08:18 PM #23
Had same thing. Bad reversing valve coil. New short ones don't fit the old units. Get on from the scrap pile or have fun replacing the whole valve.
