Results 1 to 7 of 7
    SE Michigan
    Pilot proving before Prepurge
    I have an issue that I'd like to rectify and was hoping for some comments. I have a Quattro that proves pilot before prepurging which is causing the board to time out before the pressure switch gets a chance to close. No crack in the heat exchanger and the pressure switch is good. I also checked for any seal issues in the draft motor assembly and box and all appears fine. Current PS is .52" of WC and I'm thinking of reducing that to solve the issue. Any comments or suggestions?
    SE Michigan
    Nope!
    “Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery.”
    read the site rules and repost in the proper area!!!
    He can't, he doesn't have enough post ot apply for pro membership yet.
    SE Michigan
    Thanks beenthere. I believe this post puts me at the minimum so I will apply for Pro but in the meantime I still have this issue.
    Not familar with the Quattro myself.
    But, if .52" is what the factory PS is suppose to be. I wouldn't use a different one, without consulting the factory.
    I would also check to see what pressure its sensing. The PS may be doing its job, and protecting the unit from a serious hazzard.
    SE Michigan
    The factory (Consolidated Ind) no longer exists. The Quattro was designed to prove pilot before prepurge which doesn't allow enough time for it to get up to speed. It actually will go to full fire on the 3rd tryout due to their being residual pressure built up by then.
