Results 1 to 2 of 2
Thread: Wrightsoft
    May 2008
    Last moon off of Pluto
    Wrightsoft
    I purchased Right-J, Right-D and Right-draw. I started digging into this weekend and I'm pretty much stuck on setting up my libraries. That's were you specify generic information that you'll use over and over again. Like the region you live in and construction materials.
    I'm really hung up on the construction materials. Anyone else have this problem when you manual-J calc is asking you about construction and building materials? I never know what to put.
    Clearwater, Fl
    We entered in what is most common for our area, and adjust if needed depending on the home.
    In our area, most homes are slab on grade, shingle roof, single pane windows, and wood exterior doors. Those are our standard, saved entries.
    If you have something different, you change your settings before you start drawing your home and that will change all settings for the rooms drawn.
