Results 1 to 7 of 7
    How to prepare the outside unit for FALL/WINTER?
    As a homeowner, is there anything I can do to my AC unit for the wall winter? For example, put a piece over the top of the out side unit. Call the AC company I use to prepare it for winter? Thanks in advance!
    There are no special requirements for winter for it.
    You can leave it as it is.
    Thanks!
    burlington county n.j.
    cover the top of it if it is straight a/c and there are trees near that would drop leaves in it.
    if you cover it shut off breaker so it does not get turned on with cover in place.
    i just hate having to charge people to reset the hp safety after they try to run it covered.........
    Quote Originally Posted by t527ed View Post
    There are tons of trees around it; I think it's flat(XC21). I will have to double check.
    I have a lot of trees near mine.
    Not much of a problem with leaves in it.
    The snow helps to keep the coil clean.
    Chicago, IL
    Its best to cover the top with a sheet of plywood with a few bricks on top. Do not wrap a tarp around it or use an A/C cover from the store. Those methods keep moisture in which rusts the unit. They also collect solar heat, which attracts mice that eat the wiring.
