superheat
what kind of superheat number is everyone looking for in residential ac units with fixed orifice
Use your slide calculator and check your indoor wet bulb, and that will tell you your proper superheat for your load and conditions.
super heat in a fixed orf. system is a moving target. It varies greatly with conditions
Why do you ask
Why do you ask this question Workhc
Do it right the first time.
No fixed number varies with indoor and outdoor temperatures.
Guys you haven't got a clue what superheat is.Neither of you gave a proper answer.
Whos the picture of
Is that your mom!: Where you from you sound like your french. If you want the correct answer You will have to tell me why. This is not a DIY hot line where you ask a question and get a answer. We as professional will educate you to certain degree and help you make a informative choice on equipment or services and not help you DO IT YOURSELF! We have to keep it a secret so the british don`t steal our technology
That can vary allot from 5 -15-20 depending on what temperatures are inside and outside.
Hunting -throttling -open on a TEV can be due to air-temp-obstruction.
Check airflow
Check sub-cooling
check Delta
'Life begins with the journey each day'
superheat
First of all i am not french ,second your answer is very arrogant,third i got 15 experience ...starting from a domestic fridge and end up troubleshooting VRV /VRF systems....the reason for my post is simply i did not see an answer even close to what superheat is...
Re-read the question. The question was not "What is superheat"?
The question was "what kind of superheat number is everyone looking for in residential ac units with fixed orifice"
It was answered properly by RPonson and Therm76.
Take care.
superheat
Take care.
Gary you have a sharp eye....mine is gone down ...a bit of an old man
Take care.
Exactly what I said. On the slide rule you slide it over to the indoor wetbulb you have, and then look at the outdoor temp., and then it tells you what superheat you should have.
- You may not post replies
- You may not edit your posts
Forum Rules
