Results 1 to 13 of 26
    Apr 2004
    long island
    1000 sq ft house__better off just using 2 window shakers?
    i currently live in a small 1000 sq foot house. Would i be better off just using 2 through the wall units? The lr/dr and kitchen are all open to each other and about 600 sq ft. my thoughts were just install a nice big unit for the lr/dr kit. and a small unit for my bedroom. I would leave the 2nd bed and single bath alone. What do u guys think? I ould save alot of money.any thoughts?
    Jan 2006
    Hangin out with you losers
    before making a decision you should at least pay for a load calculation to determine what type of system would be best.
    There is a good chance you are right but a load test is cheap and accurate
    what if you put in the window units and they run now stop?
    or they only last 5 years and you got to buy new ones every 5 years?
    on the onther hand
    Maybe a split wont fit
    or you will have to many upgrades to make it worth the cost
    either way you should get your place sized up
    good luck
    I remember my first day,It was fun!
    How long do you plan on keeping the house?
    If more than a couple years, a simple 13seer straight cool/ele heat (I wish 10seer was available) split will add value to the home and improve comfort, air filtration and movement over window a/c's. Plus bugs get in around window a/c and air leaks in too.
    I guess heat is not really an issue?
    You will get your money back when you sell the house and get the extra comfort for years for free.
    Having said that, I've been low in funds and know that window units will suffice.
    To the pro's,,, anyone ever compare the latent capacity of the 10 seer to the 13? Given the same low end blower, 10seer was better.
    Apr 2004
    long island
    i plan on staying a while( although i planned on staying a while in the last 2 houses over the last 10years). I currently have a hot air system, so installing a cac would be easier than not. I dont know if i could justify the price though. I could pick up and install myself a properly sized unit for the main living area for under $500. while having a cac installed will cost probably 7 times that. There def is an advantage to the cac( resale value, along with mor comfort and quietness throughout). I have a hard time spending that much more though when i can achieve similar results much much more cheaper. I have the next 2 seasons to make the descision. I guees if anyone has any other thoughts, let me know. thanks
    I don't know
    Get quotes prior to making assumptions; you may only require a small 1.5 ton unit depending on your climate and building envelope.
    Depending on what area you live in.
    You might be able to justify, installing a dual fuel heat pump instead of just a CAC on that furnace.
    somewhere between heaven and hell
    Quote Originally Posted by amd View Post
    That are my thoughts exactly. This sounds like a small house to me. Just for your information lets say your load calcs only calls for just a one ton unit I was just told that Coleman actually makes a 13 seer 1 ton central air conditioning system. I thought that was odd but it might be cheaper than going 1.5 ton. BUT depends on load calculation. Get qoutes.
    York/Luxaire/Coleman UPG, came out with the 1 ton units a little over a year ago. maybe 2 years now.
    4H: Hot, Humid Houston H.O.
    One benefit to window shakers is you won't have to worry about ductwork, sizing it correctly, ensuring no leaks in the attic etc.
    I am a homeowner with a larger house and 2 central air systems, so just pointing out some disadvantages of central forced air.
    Best of luck -- Pstu
    East central Indiana
    The condenser I install the most is the Texas Furnace Spartan series (texasfurnace dot com, model 2AC13 series). Nominally, they have a 1.5 ton system. I've never checked ARI btu ratings, but from experience, it usually only pulls about 5.5 amps. So, I'd guess it's a "light" 1.5 tonner.
    Yea I just found out the other day that they did. Of course I don't see many of those units here. How well do they work? My Johnstone sales guy was telling me they have them in 1 ton if I ever needed a 1 ton unit at anytime.
    I haven't had an application for one since they came out.
    Could have used one several times before they came out though.
    Apr 2004
    long island
    i got 2 qoutes already. both said 1.5 was good. I know we cant discuss prices here, but as i stated earlier, it would cost about 7 times the cost of a window shaker. I live on long island ny, and have noticed everything here costs twice as much as anywhere else. I live in a middle class neighborhood, but unfortunately long island tends to be affiliated with upper class, so prices tend to reflect that. Maybe over the fall/winter i can find a local hvac guy to do the job at a fair price. anyway, thanks for the comments.
