Results 1 to 12 of 12
    Cracked Converter
    I have an 11 year old Tempstar 2 ton gas / electric package unit, which provides heat and ac to the downstairs of our house (1,500 sq downstairs). It has a leak in the condenser and cracks in the converter. I will be replacing it in the near future, but want to know if I can hold off till spring.
    I was told the cracks in the converter let carbon monoxide escape. One technician said that since the unit is outside, there is no risk to carbon monoxide poisoning in the house. Another said that it could get into the house and it should be replaced immediately.
    Any clarification that you can provide would be appreciated.
    Thanks, Ken
    Aug 2008
    Burlington , Mass
    When you say "converter' , do you mean the "heat exchanger" ? If so, dont even turn the heat on.
    NW burbs of Detroit
    Assuming you mean heat exchanger since you voiced concern about co getting into home.
    There are a couple different schools of thought on weather to its a problem or not.
    My personal position is if you have ceacks that measureable amount seeping thru then I would err on the side of caution and replace ASAP.
    You never know when a small crack will become a big one, big enough to cause co to move into a home.
    The only thing waiting will do is create a very dangerous situation for you and whoever lives in the home during the winter. Also equipment is only going up in price so you will pay more in the spring. Take advantage of someones interest free financing if the budget is too tight right now.
    I appreciate the input. I understand that picking the installer is the most important choice, but are there any impartial rankings on the quality of the major product lines? I'm looking at a 13 or 14 seer unit. Possibly a flex fuel. Mainly looking between Trane, Lennox, Carrier and Rheem.
    Thanks.
    Altmar, New York, United States
    what is a flex fuel?
    Jun 2007
    The Twilight Zone
    Quote Originally Posted by snupytcb View Post
    Fuel that bends.
    flex fuel / hybrid
    These package systems (I know Carrier and Trane both carry them), have electric for A/C. But for Heat, instead of using all gas, they use electric down to a certain temp (which I believe can be adjusted - heard it called the balance point) and then use gas under that temp.
    A duel-fuel package unit would probably be a good choice but expect to pay more upfront. Over the life of the unit it should easily pay for itself and put money in your pocket. 13 or 14 seer are fine in my opinion. Pick yourself a good installer, make sure they size the unit properly and good luck. Also have ductwork looked at.
    sorry, dual fuel package unit is what I meant to say. These are also referred to as hybrid.
    Trane, Lennox, Carrier vs Rheem
    Any thoughts on Trane, Lennox, Carrier vs Rheem?
    Apr 2008
    il
    go with a york modulating best furnace i have installed and or worked on
