+ Reply to Thread
Results 1 to 20 of 21
Thread: Combustion Fan Runs Constantly
    Nashville, TN
    Confused Combustion Fan Runs Constantly
    Let me start out by saying I'm a maintenance technician at a manufacturing plant in Nashville, TN. While I do have a Universal license and have some formal training, I wouldn't dare lie to anyone and say that that I'm an HVAC Technician. I get by, but when it gets deep I call on my more qualified colleagues. Having said all that, here's my dilemma: While changing filters on 15 ton Trane Voyager package unit, I noticed that the combustion fan was running. I'm not sure what the exact temp was but it was somewhere in the 80's. I checked the t-stat and it was calling for cool not heat. My first reaction was to kill the disconnect and let it sit for a minute or so thinking that it might reset itself. As soon as the disconnect was turned on, the combustion fan came on. My next step was to swap out the ignition module/board with another unit of the same model. The combustion fan continued to run. Finally, I removed the fan assembly and installed in on another 15 ton Voyager, same model, that was operating properly. When I turned the disconnect on the combustion fan immediately came on. Needless to say, the problem is in the motor, I got that, but my little brain tells me that a motor doesn't do anything until its told to. One other thing I forgot to mention, this unit is just under 3 years old and this is the 2nd time this has happened. Fortunately this part is still under warranty and I intend on swapping it out tomorrow. Now, like I said I know what to do to correct this, but does anyone have any idea what could cause this? Is it just a fluke? Maybe the motor was assembled on Monday or Friday! Who knows, just thought I'd throw that out there. Any insight would be helpful.
    Hampton Roads, Virginia
    Its the motor, a common problem on these units.
    Kevin
    Controls is a lifestyle not a job
    Jul 2001
    Got any limits tripped or open? What does the schematic show in the fan circuit?
    houston, texas
    Trust me the motor is bad. We find them all the time
    I'm not tolerating Political Correctness anymore, from now on it's tell it like it is.
    Veto Pro Pak - The best tool bag you'll ever own
    Jun 2007
    Darby, PA
    Seen same issue numerous times...it's the motor!
    Psalm 51:10, 12
    Dec 2001
    Chicago, N/W burbs
    it's the motor. you'll need an inducer assembly.
    R2B4BTU
    omaha
    agree you need a motor
    Apr 2008
    il
    its the motor just went through same prob
    May 2008
    Last moon off of Pluto
    What causes this?
    Nashville, TN
    Yeah, there's no doubt that the motor is gone. This is the second time in 11 months. I'm just wondering what causes this. From what I'm hearing here and other places, it's a common problem. Just wondering if anyone knew what the root cause is. Thanks for all your responses.
    SE Michigan
    Motors do not just kick on unless they have voltage sent to them. Not sure what you guys are talking about but I'd be checking voltages before calling it a motor.
    Dec 2000
    Victorville Ca
    Quote Originally Posted by tlrutko312 View Post
    Ya ME TOO I would first look for open limit
    omaha
    this motor is feed voltage all the time
  14. #14
    Dec 2001
    Chicago, N/W burbs
    It's a single phase motor with one leg constantly hot. The internal windings develop a shunt and this causes the motor to run continuously.
    R2B4BTU
  15. #15
    East central Indiana
    LOL,
    My uncle runs a supply house. He still tells the story, happened some 10 years ago, about a guy who changed out a blower motor because it ran all the time.
  16. #16
    Toledo, Ohio, United States
    Twilli says the thermostat.
  17. #17
    Apr 2008
    chicago
    dont motters do what there told to do?????
  18. #18
    SE Michigan
    Quote Originally Posted by otto View Post
    Can I assume what you are saying is that the "shunt" you are referring to acts as a neutral?
  19. #19
    Mar 2001
    Seattle
    Trane has put out a service bulliten about this. Like others have said it is the motor. I have replaced 3 myself. The last time when picking up the part at my local trane parts they asked me what the motor was doing, I told them and they gave me the part for free.
  20. #20
    L.I. NY
    I do not know trane but on yorks the motor is 208 volt and only 1 line is switched, the other line goes to the line side of the compressor contactor. If the motor windings short to ground someware around the middle of the winding the motor will run on 115 volts. It may not get to full speed but it will run.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
