Results 1 to 2 of 2
    Apr 2004
    Should I add a cold air return to my basement?
    When I purchased my home the basement was not finished, which it is now. My question is should I have my contractor cut in a cold air return somewhere in the basement? One of the contractors I had out suggested that it would be a good idea because in the summer it could circulate some of the cool air from downstairs to the rest of the house (I am getting the G61V furnace). I am a bit concerned that it could upset the "balance" of the system, being that the ductwork was not originally designed with a cold air return in the basement. Note that the furnace is located in the basement in a seperate, unfinished utility room. Thanks.
    Lincoln, Nebraska
    When we do a house with a basement the equipment and duct is sized for a future basement finish. It should not be a problem adding a return. We usually cut a few registers in the supply duct also and with adding a return it will help mix the house air and keep the humidity lower in the basement.
    Its a good Life!
