Thread: Boiler Maintenance
09-10-2008, 08:29 PM #1
- Aug 2006
- Windsor area Ontario Canada
- 280
Boiler Maintenance
confused:What is the best things to do for a residential boiler maintenance, i usually, clean the burners check gas pressure, check expansion tank pressure, bleed air at bleeders if needed, amp pump, is there anything else that can be done? do you flush the system if so do you do it every year? thanks for the suggestions:
09-10-2008, 08:40 PM #2
Wrong forum. This question belongs on the technical forum.
09-10-2008, 09:39 PM #3
- Aug 2006
- 280
well can i get an answer because they never gave me a proffesional membership, i have probably 50 posts and you only need 10 for proffessional and i have my g2 and has been to school twice for refrigeration you would think they would give me a professional membership........anyways i just want my question answered thanks
09-10-2008, 09:46 PM #4
What does that word under your name mean?
Expect nothing, yet expect the unexpected.
Press on Regardless, Endeavor to Persevere.
09-11-2008, 05:21 PM #5
- Aug 2006
- 280
Lmao!!! sorry i didnt even know they gave me the professional member!
