Page 4 of 5 FirstFirst 12345 LastLast
Results 40 to 52 of 54
  1. #40
    Aug 2008
    That I'm not sure of. I think I do have a backup heat strip, but this is a heat pump. I can tell you if its hooked up to the thermostat what port should a wire be in.
  2. #41
    Aug 2008
    Right now they have a wire going from DHM2 to C and DHM1 to RH. I thought DHM2 should be wired into the air handler. Right?
  3. #42
    Rochester, MN
    Quote Originally Posted by sakit2ya View Post
    Oh god no! THey need to get that wire off C before something shorts off!
    They have to read the install manual! You are correct, DHM2 should go to the airhandler.
  4. #43
    Aug 2008
    They are on their way BACK out lol
  5. #44
    Naples, Fl
    This is only a test.
  6. #45
    Aug 2008
    They are out now. Any help as to what DHUM2 should be hooked to on the air handler?
  7. #46
    Aug 2008
    The guy is having a terrible time so far. The thermostat itself just went blank with the light actually cutting off to it. Ok Hes got it on and Honeywell told him to take C off, but hes not sure where to connect DHUM2 to the air handler. He doesn't see a low fan speed in the instructions. He saw We or something he thinks might be it. Anybody care to call the companies phone number or something like that? I think hes about to call his goodman rep.
  8. #47
    Aug 2008
    I think its working now. He cut the wire at p something and it seems to ramp up and down. When you call for dehumidification it ramps down.
  9. #48
    Rochester, MN
    Looks like he got it at last.. Hope they learn something out of this, and able to do it right for the next one around... (If they will sell the IAQ again)
  10. #49
    Aug 2008
    Yeah I dunno. They sell mainly carrier with the infinity thermo's. He said they haven't installed any other systems that had comfort type stuff. They have installed other VS air handlers just none with the IAQ stat.
  11. #50
    I hope they read the instructions for the Infinity's better then they read your Goodman instructions.
    The clipping of that jumper is in the install manual.
  12. #51
    Aug 2008
    Indianapolis
    I think I might have someone else look at it. Lots of stuff there to go wrong or be set wrong. Common back to dehum2??? dunno about that one
  13. #52
    Quote Originally Posted by dkurmay View Post
    Control wiring is NOT that techs specialty.
