Page 1 of 5 12345 LastLast
Results 1 to 13 of 54
    Aug 2008
    Honeywell IAQ on new install... problem?
    Hey guys I'm not sure whats going on my install was completed earlier today and its a goodman variable speed air handler. Anyway the air hasn't cut off yet and its set to 78 and it says the inside air temp is 72 now. Whats going on. Is this normal?
    Naples, Fl
    get the installer back
    Aug 2008
    Just called him. I called honeywell and they had me set it to off. The system still ran. I then took it off the wall. It still ran. So I guess they hooked it up wrong.
    Any tips you can give for when the guy gets here to hook it up?
    Afton, VA / Khorat, Thailand
    Tell 'em to send an exorcist...
    Midnight Sun Astrophotography
    Aug 2008
    Any help guys? They are here but so far not much luck...
    Tell him to reread the install instructions for both the IAQ, and air handler, and outdoor unit.
    He probably has a jumper were it doesn't belong.
    What did they check so far.
    Aug 2008
    They had to run back to the shop to grab the instructions for the air handler and condensor.
    Aug 2008
    Indianapolis
    he must read the instructions a few more times. when in doubt read ,read and read some more. Call Honeywell ,my first experience with the iaq required me to call honeywell and lennox(thats the equipment) to get it working and this is on my house. its a 3 wire stat so that parts easy. it has to be in the wiring or a bad IAQ board (my first one was bad). is it just the blower thats running or the a/c too?
    Aug 2008
    It was both. They found a jumper that corrected the problem. It will now cycle on and off as it is supposed to. They just left.
    How do I call for humidity control to make sure that is hooked up right? It shows my humidity at 56% but I see no way to change that. When I click on more it only shows humidity in bigger print. Appreciate your help guys.
    Aug 2008
    Indianapolis
    under humidity level should be arrows on left to go from auto to off when in auto there are arrows on right to change setpoint
    I have to ask. Any chance you went with the lowest estimate? You should not be having to get online to figure out how to use the system a contractor just installed. They should go through everything
    They mauy not have enabled it.
    Push more.
    Then push it again until you see it say dehumdider.
    If it won't come up. Its not enabled.
