Results 1 to 13 of 14
    Cincinnati, Ohio
    3/4 Suction Line ?
    Changing out a 3 ton 10 year old Carrier 10 SEER with a Luxairre 13 Seer, condensor & evap.
    The Carrier has a 3/8" liquid line & 3/4" suction - 35 ft. length, 5' rise.
    The Luxairre calls for a 3/8" liquid & a 7/8" suction.
    Questions is - Will I just loose a small amount of effeciency by staying with the 3/4" or any other concerns?
    Thx
    Why not install what the unit has from the factory?
    Cincinnati, Ohio
    Trying to save the expense of a new line set
    Sep 2003
    Go ahead and use the 3/4 line set. It will void the warranty that comes with the unit. I don't think the customer will mind.
    Ohio
    Not only will it void the warranty from the factory but .....
    ......dude it's just not right
    Quit trying to save a few bucks and do it right.....hell, take the old lineset to the scrap yard....you'll make back half the cost of the new lineset.
    I need a new signature.....
    NW burbs of Detroit
    "A GOOD SERVICE TECH DOES NOT KNOW EVERYTHING BUT KNOWS WHERE TO FIND THE ANSWERS[I]
    Are you even a professional service man?
    Jul 2001
    Gold Coast of Connecticut
    Return it for the r-410 unit that has a 3/8 3/4" requirement.
    Aire Serv of SW Connecticut- Gas heat, dual fuel and central a/c systems installed and serviced
    Cincinnati, Ohio
    Confused
    Yes, I'm a tech, but a Chiller Specialist, not residential.
    Just trying to help out a friend & save him some $.
    Ask a simple ? & get hammered.
    Nevermind.....I'll try a more cival forum
    NW burbs of Detroit
    Quote Originally Posted by stfd47 View Post
    If your a pro than put it in the profile.
    If you had a problem with a chiller I bet you'd know exactly where to for specs.
    Extend your self and call the factory or how about the install instruction?
    But your question is also basic theory. Of course it will lose effiency.
    NW burbs of Detroit
    Tn.
    Quote Originally Posted by hvaclover View Post
    What up wit that.You right
    East central Indiana
    Quote Originally Posted by Freezeking2000 View Post
    Restocking fee > cost of new copper.
    Burleson, Texas
    IMO, no big deal, maybe a 1% to 2% capacity loss depending on the TEL of refrig lines..
