Results 1 to 10 of 10
Thread: Trane A/C info
    Tyler, Tx.
    Trane A/C info
    Can someone decipher the numbers on this unit for me
    Mod# BTD736B100A0
    Ser# Y26213970
    Outside unit
    Dallas & Longview, TX
    3 ton 10 SEER manufactured in 1997.
    Just a guess. Let the pro's verify.
    B is an oldie from the GE days. Sometime in the 80s, I would say in the 8 SEER range. It is a 3 ton though.
    Tyler, Tx.
    this a/c is in a house that is 2200 sq. feet.
    It seemed to cool off pretty well, but that seems like a small unit for the size house. What do you guys think?
    Matt
    Illinois
    Quote Originally Posted by mattdzero View Post
    Matt
    No one can tell you without doing a load calculation...could be to small, to big or just right...
    Tyler, Tx.
    hmmm! can a regular a/c guy run this test? Is it pretty expensive?
    DC Metro area
    You can do it yourself (at a price) by clicking the HVAC-Calc link at the top of the page. It involves determining insulation factors, window factors, and more... Few companies will do them for replacements, but it's certainly a good way to determine you have the proper-size system. Does it cool well on the hottest days? Does it short cycle or long cycles on hot days? 2200 sq. ft. on a 3 ton doesn't sound out of the ordinary for my area, but it varies by area and construction type. Texas can get hot... you say the unit cools well, though.
    Lancaster PA
    If its cooling the house, and keeping the humidity down.
    Going to a larger unit, would raise the humidity in your house, and cause you to set your stat lower to be comfortable.
    Tyler, Tx.
    Really? I never tought about that. It would raise the humidity.
    The house I am in now has a brand new trane 3 ton 13 seer unit that I had installed and on really hot days(in the 100's) if I were to set the thermostat to 70 it would probably never reach it until evening. My house is only 1450 sq. feet.
    I love my a/c though.
    Lancaster PA
    On the days when its not at 100°.
    Its on time would be less, and it would remove a little less moisture from the air.
    How much less moisture varies with how much shorter the on time is, and some other factors.
