Results 14 to 26 of 27
Thread: return size ?
    May 2008
    thanks dash that helps alot.
    May 2008
    dash will the return size matter on the btus of the system, will it affect its performance as far as cooling. besides the noisy return, the reason i ask is because my old 3 ton system had a 14x25 return grill and it was a little noisy but did cool the house down to comfort level
    May 2008
    i quess i will have to make two return griles. two 16x25 = 800 or two
    14x 25=700. the only thing is that the other return is going to be on the other side of the wall that this unit is not cooling. the other unit is the one that is cooling this other side of the wall.
    Naples, Fl
    Are they open to one another or separated by doors and walls?
    May 2008
    if i understand you correctly they are separated by walls. but the wall behind the air handler is being cooled down by the other system. i have a 2600 square foot home single story with two units. hope i made sense i sometimes tend to not fully explain myself correctly
    You don't want the second return from system A to be in the area that is cooled by system B,unless they are totally open to each other,basd on the second return location.
    May 2008
    thanks dash for your reply. the second return from system A will be about thirteen feet away from system B return will this be considered as totally opened to each other ? i understand that system A should have its own return to be able to pull its side of the humidity. the situation im in is that i do not want to force my newly installed air handler by not giving it its required return size, this will shorten the life of my air handler in my opinion besides the noisy return.
    there are no walls between the system A second return and from system B return. basically both systems A second return and system B return would be considered as if they are in the same room facing each other with thirteen feet away from each other but in the same room with no walls dividing them apart.
    Its not if the returns of system A and B are open to each other.
    Its if system A's supply air can freely travel to the new second return for system A.
    May 2008
    no system A's supply air can not freely travel to the system A's second return. so i assume this is not a good idea. can you educate why this is not acceptable besides it pulling systems B humidity.
    A. It puts the area served by system B into a negative pressure.
    B. It puts the area served by system A into a positive pressure.
    So B's area draws unconditioned air from outside through door seals, wall cracks, recepts, and switches.
    And A's area blows the air you just paid to condition outside.
    In order for a return to work. It has to be able to get the air from the supplies of the area its to serve.
    Its kind of like having 2 pick ups. And putting 2 gas tanks on the one for long trips.
    But then driving the truck with the single tank instead. Plenty of gas in the duel tank truck, but not enough in the one your driving. And no way for teh gas to get there.
    Tn.
    It took me a few years to learn formulas for calculating face grille size.
    Nowdays hop on the internet and there you go.
    Shelby Twp MI
    System A is designed for system A period. If you put the second grill in for A in B's area, it will quiet the return for system A. However, your now starving the return for system A's area. What I mean is, you will not pull the required CFM's out of system A's space, hence the system will not work efficiently or properly as designed. You'll be pumping more INTO A's space than you are taking out. Understand?
    Jim
    Quote Originally Posted by junior1 View Post
    Closed door separating them,or what??
