Results 1 to 2 of 2
    web server port for ilon 100 e3
    Just a quick question, I was using ilon 100 e3 yesterday & changed the web server port to other number instead of 80. So i can't access to ilon 100 webpage via HTTP.
    If I connect ilon e3 as console & format it will all the settings become default? which means web server port will set to 80 again.
    thanx alot
    NY
    If you add the port number at the end of the IP address you should be able to access the webpages. Add the port number like this 192.168.1.222:8080.
    The other option is to access the console app. and change the port back to 80 there.
