Results 1 to 13 of 28
Thread: new thermostat
09-02-2008, 10:27 PM #1
- Feb 2007
- Las Vegas,NV
- 719
new thermostat
Hey guys, my focus pro thermostat has taken a dump. I am considering changing it out with the vision pro unit, I also see that White Rodgers has a simillar touch screen unit but I dont see anyone talk much about them here.
I would like to see a few opinions on both units, is it really worth upgrading to?
We dont have humidity issues here and dont have any add ons, all the thing needs to do is turn the unit off and on. I do however like the touch screen feature.
Would appreciate any input. Thanks
09-02-2008, 10:36 PM #2
Professional Member*
- Mar 2004
- Chester County PA
- 285
The advantage to the Vision Pro 8000 is that it is so versatile. You can do so much with it in the configurations menu and adapt it to many types of units.
It comes down to personal choice since you said you have a basic system with no Indoor Air Quality products.
If you don't have anything on your system then you're missing out. No matter where you live there is something out there that will make the air quality in your house better. Whether it's a humidifier, Dehumidifier, UV lites, air filtration setup or whatever. Everything is tailored around the area you live in.
If you want a touch screen I would stick with the Honeywell.
If you want something simple and cheap buy a Honeywell round (no touchscreen feature)
(psst... if you don't have a variable speed blower you're missing out)
~smoke~"That motor's done, he let the factory smoke charge out!"
09-02-2008, 10:42 PM #3
i have installed both. I prefer the vision pro and have it in my house. I have not had any problems with either but I prefer the HW for its setup makes a little more sense to me. Also do not skimp out on features HW can do it all if you get the loaded model (IAQ). it was not available when i got mine so I just have the one that does humidity. Dry winters here and adding humidity saves me money on my heat bills. I may install a uv light and I have read that it has features for it as well. My utility companies web site has trending set up for usage versus many other variables such as outside average temperature, comparing similar months it has saved me around 15% versus the old WW programmable that we had, I attribute that to multiple occ periods/setpoints and more effective temperature control along with the adaptive recovery features.
Build it and it will break. Fix it and it will work. Ignore it and will cost more. Patch it and it will get worse. Cross the bridge before the flood.
09-02-2008, 10:53 PM #4
If you don't need any thing special, in teh stat.
If your focus pro is less then 5 years old. Good chance its under warranty.
09-02-2008, 11:11 PM #5
- Feb 2007
- Las Vegas,NV
- 719
Thanks beenthere, the focus pro is still under warranty. I know the vision pro wont benefit me but damn I like the way it looks! Just hard to justify the extra money for it.
To skwsproul, I would like to have a humidifier but with a roof top unit there is really no where to put one.
To smoke, no variable speed, just basic 13 seer pack.
09-02-2008, 11:12 PM #6
09-02-2008, 11:14 PM #7Build it and it will break. Fix it and it will work. Ignore it and will cost more. Patch it and it will get worse. Cross the bridge before the flood.
09-02-2008, 11:39 PM #8
- Feb 2007
- Las Vegas,NV
- 719
I have seen people here hang humidifiers off the side of the elbow on the roof, bad.
I have heard of people putting them in attics, another bad.
I thought once of mounting it in the laundry room and ducting it in, at least in there we have a floor drain.
Central humidifiers here are not common even though we are very dry. Most people including us use a table top p.o.s. that has to be filled twice a day.
Out of the many focus pros I have bought and installed, mine had to be the only one to take a crap! I have temporarily thrown an old round on the wall until I decide what to do.
09-02-2008, 11:44 PM #9Build it and it will break. Fix it and it will work. Ignore it and will cost more. Patch it and it will get worse. Cross the bridge before the flood.
09-03-2008, 06:04 AM #10
The Honeywell Tru Steam humidifer can be remote mounted.
09-08-2008, 02:55 PM #11
- Feb 2007
- Las Vegas,NV
- 719
Well guys, I settled on the Vision pro 8320, I guess I will finally get to see what all the hype is about with these things!
I like the fact that it can always stay dimly lit in our dark hall, now I dont have to fumble with light switches everytime I want to adjust it.
09-08-2008, 06:23 PM #12
- Feb 2007
- Las Vegas,NV
- 719
I know if I buy an outdoor sensor that I can use the aux heat lockout feature but according to the setup menu only goes down to 40 degrees, is this true?
I have a lockout stat up in the unit set for 30 degrees, if the vision pro wont go that low, I will just leave it the way it is. Thanks
09-08-2008, 07:28 PM #13
40, is the highest compressor lock out temp.
Heat pump compressor lockout
0 No heat pump compressor lockout
[Other options: 15, 20, 25, 30, 35, 40°F (-9.5°C to 7°C)]
I forgot about that.
