    Desuperheater - Air to Air
    Has anyone ever installed a desuperheater on an air-to-air heatpump system?
    Any thoughts/ recommendations/ feedback?
    These are obviously prevalent on geothermal but I can't seem to find a lot on air systems.
    Jun 2001
    DFW
    They used to be more common.
    Modern heat pumps run at a lower temperature that allows preheating of water, but will require supplemental heat.
    In an air-to-air system, you also run into issues with freeze protection that are not a problem with geothermal.
    Feb 2007
    out in the country
    I saw a desuperheater on an air to air HP once. The desuprheater was mounted next to the outdoor unit, it was well below freezing that day, the desuperheater made a very big ice cube because it had froze and busted due to the outdoor temp.
    Thats where the problem is, the design of a desuperheater requires being connected to the discharge pipe coming off of the compressor , thru the desuperheater, out of the desuperheater and into the reversing valve. Unless you have a geo or a triple split unit these connections will be outside. Most areas its not a good idea to have water lines outside and exposed.
    I never let schooling interfere with my education... Mark Twain
