Results 1 to 11 of 11
    Aug 2008
    TRANE model# TUE100A948K2: motor upgrade
    We have been happy with our Trane indoor Forced Air furnace with model # TUE100A948K2, except that the upstairs is never as cool as the downstairs, and when it finally gets cooler upstairs, the downstairs feels too cold. We are therefore thinking of upgrading the motor to push the cold air more quickly upstairs. Is this a good move? Which upgrade would you recommend? Any specific model of a motor you could recommend?
    Dec 2006
    Middle Tennessee
    Quote Originally Posted by ksr View Post
    if your thinking about putting a bigger motor than the unit is designed for, then it's a bad move!
    sounds like you have a distribution problem!
    heat travels up, it's gonna be hotter upstairs in the summer "as well as the winter"
    you may want to consider zoning your duct system to fix that problem if other methods don't work!
    Aug 2008
    Minneapolis
    colder air is more dense and will fall to the lowest level. Do you run the furnace blower in the fan ON position that can help some with thermal-cline between floors.
    Aug 2008
    quote:if your thinking about putting a bigger motor than the unit is designed for, then it's a bad move!
    I had to change a 1/2 hp to a 3/4 hp motor on a 3.5 ton to get the correct fpm. The mfg had spec'd a 1/2 hp motor. FPM went from 430 to 680. Of corse I checked the temp rise and the external static as well as the amp draw on the motor. All good
    If you put in a bigger motor to push air upstairs faster. It will also push air to the first floor faster.
    You have a distribution/balancing problem, not caused by the blower motor.
    Aug 2008
    The 1st floor wasn't getting enough air either. A 1940's 2 story house.
    Quote Originally Posted by pipefitter636 View Post
    I was talking to the OP.
    Way to confuse the thread with your solution to a different kind of problem than was being asked about.
    Aug 2008
    Sorry Didn't mean to try to confuse the thread.
    Mar 2002
    Hot Rises, cold air falls, simple as that. You need to be able to ballance the airflow accordingly to send more heat downstairs in the winter and more cold air upstairs in the summer.
    Automated zone controls are by far the best solution - you get the right temperature at the right place at the right time. If you can't afford zoning, however, you can install adjustable dampers to seperate the upstairs ductwork from the downstairs ductwork. For example, you might need 60 up 40 down in the summer amd 60 down 40 up in the winter.
    Jun 2007
    Round Rock
    Putting a bigger motor to push more air faster upstairs. That is ridiculous and a complete waste of money for a new motor. I hope somebody that does this a living didn't suggest that too you. If so, tell them where to go. I guess it will magically not push the air to the bottom floor just as fast? There is no simple fix for this, it will cost $$$ and take time.
