Results 1 to 13 of 17
    277 volt fan powered box rheostat
    277 volt fan powered box rheostat. I don't even know if I am spelling it correctly....
    Anyway, I have about 40 dual fan powered boxes that run single phase 277 volt motors. The original configuration had a rheostat that you could dial in the desired RPM of the motor.
    Does any one know where I could find suitable replacements with out having to buy 80 multi tap motors and spend all that time and money?
    Southern, CA
    Be helpful to know what you're doing. Is this a job, or a big pile in your back yard? What do you want to run them on now, 460 - 3, 460 - 1, solar, husky mice?
    Their in a old county building. Most of them are running just fine, but a few are over blowing the registers and making too much noise, causing complaints in courtrooms, etc.
    All motors are 277 single phase.
    In years past balancing the air was as easy as dialing the desired rpm via the rheostat. Someone somewhere must make drop in replacement.
    Jan 2003
    Kansas City
    Grainger carries one I believe, but I cannot find it online. Worst case scenario, call a Nailor distributor or any other fan powered box distributor and they will be able to get you one.
    what brand box do you have? got a model # you can get speed controllers at most hvac/electrical wholesale houses.
    AIRFLOW IS CRITICAL
    You can get multi tap motor controllers and or temp sensor and pressure controllers at the parts house but not rheostats, but these are single speed motors.
    The rheostat system worked well with these single speed motors but now that the building is 10-12 years old the rheostats are starting to fail.
    I must of left the Mfg. and Part #'s at work, I will get them today.
    I was hoping that one of you commercial guys had run across this be for and had a source for me.
    Did look through the Grainger book and found nothing. Still looking.
    hey j-fish, here is a data sheet on the ones we use.You can get them at johnstone supply.http://www.johnstonesupply.com/corp/...t_Code=G32-399 good luck
    AIRFLOW IS CRITICAL
    airdata870, that is exactly what I was looking for. Funny, they were one of the first places I called and they were not able to help me. Guess they are only as good as the knowledge they posses of their products they offer.
    Thank you all for your help!
    Ohio
    If it's a series VAV box, forget about the multi-tap motor. You'll need to dial in the design cooling CFM with the rheostat.
    jogas
    St Paul, minnesota
    using those controls will cause the motors to overheat. they're usually only used on small exhaust fans ect. For VAV boxes what you need is a SCR solid state speed controller. they use a triac to adjust voltage sometimes called phase proportioning or wave chopping.
    look here
    http://www.nailor.com/OnlineCatalogs...6/CATGENIN.pdf
    see page G17 & G18.
    good luck
    Quote Originally Posted by superfittertech View Post
    look here
    see page G17 & G18.
    good luck
    superfittertech, could you explain the diference,the kb uses a triac to adjust voltage. my uderstanding of the overheating comes from slowing the motor down to far.
    AIRFLOW IS CRITICAL
    May 2005
    Lubbock Texas
    KB electronics
    Nov 2003
    Montreal, Qc.
    What is the HP and RPM of the motor and what is the percentage you want to slow them down?
    I installed around 150 of these back in the mid 90's.
    They were reliable as long as the reduction in speed wasn't over 40%-45A%.
    From 50% and above the instances of failure increased greatly.
    There is a minimum speed trim pot on the controller.
