Results 1 to 11 of 11
    19 DK with control problems
    I have a 19 DK that alarms on 64, but only in remote on the MP 3200 when in local all is good has anybody seen this before? I also have 38 steps on the control test instead of 34 or 44. and last but not least the 64 is supposed to be sensor out of range with the sensor number that is at fault displaying next but it doesn't happen. All test points and control tests are good as are the transformer voltages. Banging my head on the control panel won't make it work any suggestions?
    Colddr
    The Great country of Texas
    Does it have an ESP I or II on it?
    "I'm from Texas, what country are you from?"
    Esp Ii
    Second City, USA
    Not much detail here, so this is a shot in the dark - got matched software?
    Are you using chilled water reset or current reset thru the ESP? If so, you could be losing the signal and that is why you are getting the code.
    I have swapped out the processor board, I/O board and MP 3200 with used
    boards we had at the shop and still get the 64 error code when I disconect the ESP I still get the code on the MP3200. so I guess my question is does anybody have a method for checking the memory expansion board, When I disconect it there is a com failure which makes sense.
    Any help would be good.
    the remote signals are not enabled
    Is the ESP programmed for something you don't have like chilled water reset or current? You have to give it a 0 or 1 to activate. Also, have you checked the S1-S4 dipswitches on the micro for correct settings?
    It was the remote temp reset was enabled but it had no 4 - 20 milliamp signal
    so it saw a value less than 0 and thus the sensor failure. Thanks for your help it got me going in the right direction. ( I was the 4th guy on this job so it was frustrating sifting through it all)
    N.E. IA
    colddr469
    Which job was this 19DK on?
    referteacher
    "Wheel" mechanics work on "Wheel" chillers
    Quote Originally Posted by colddr469 View Post
    I except, cash, check or credit card! LOL
