+ Reply to Thread
Results 21 to 31 of 31
Thread: Water in bottom of True Refrig
  1. #21
    Apr 2005
    Australia : Queensland
    Yogurts have plenty of bacteria in them & id dare say a fair heat-load due to the molecule collisions. Sounds plausible.
    The primary function of the design engineer is to make things difficult for the fabricator and impossible for the serviceman.
  2. #22
    Aug 2009
    Maine
    Or both, that means she is faking it. (:-
    Quote Originally Posted by UmmScott View Post
    Or both..?
  3. #23
    Jun 2009
    DFW, TX
    Hammer a dent into bottom of box, penetrate a hole into the dent in the base, flared copper drain stub, silicone, etc. Problem solved
  4. #24
    Quote Originally Posted by TechmanTerry View Post
    Put the yogurt on sheet pans to collect the dew drops to see if it dripping from the containers
    Check out the big brain on this guy ... novel idea
  5. #25
    Quote Originally Posted by trippintl0 View Post
    If the post above points to the jugs , I just may do that
  6. #26
    Oct 2011
    Chicagoland Area
    Did someone say jugs?
    Why is it that those who complain the most contribute the least?
    MONEY CAN'T BUY HAPPINESS. POVERTY CAN'T BUY ANYTHING
  7. #27
    I forgot what i was gonna say ....
  8. Likes 2sac liked this post.
  9. #28
    Oct 2014
    SoCal
    I'd collect the sweat off those jugs!
  10. Likes 2sac liked this post.
  11. #29
    Aug 2009
    Maine
    Doesn't some one make an evaporator drain kit. wouldn't that work.............
  12. #30
    May 2008
    S.E.Virginia
    I have seen this problem when the door gaskets are shot.
  13. #31
    Sep 2010
    miami,fl.
    [QUOTE=trippintl0;21221331]Hammer a dent into bottom of box, penetrate a hole into the dent in the base, flared copper drain stub, silicone, etc. Problem solved[/QUOTE
    Also once your copper stub leaves the bottom of the fridge make sure you add a trap to it. To create a seal in the drain pipe. I would add a piece of poly tube underneath.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
